Mobil 1 Oil users
#211
Originally Posted by bythabay
I'm not sure what the deal is but I'd like to see some used oil analysis results from that one once it is drained. I think running that might be way too much for the VQ... but oil analysis could prove me wrong
As for changing the filter without changing the oil, it's pretty straight forward. The oil sits in the oil pan and only whatever is in the filter area will drain out. The oil that is in the pan will not drain if you remove just the filter.
#212
#213
Standard filters should be fine, but I think I would at least go with the factory filter or another "long life" filter like K&N, Mobil-1, or Amsoil.
I started using the "bigger" Mobil 1 in my G35. The part # is M110.
There's a whole slew of Group 4 100% synthetic oils out there. You just need to decide on which viscosity you need.
I'm using Mobil 1 0w40 with the M110 Filter.
#214
Thanks for the info! i didnt my oil 500 miles ago with royal purple, i only heard good things about it so i figured it would be good, but didnt really look into it. before the most recent oil change i used M1
recommend any filters with this euro castrol?
im gonna check pepboys to see if they got the 0-30 euro blend when i go into work, if they dont have it, autozone it is!
#215
#217
Originally Posted by Nikos35
I always used M1 for my veh. NO MORE M1!!!! I will use something else. I have been M1 for about 10 years, never again!!!!
German Castrol 0W30 is also great oil with those same ratings above (Group 4). But basically my tests of Mobil 1 samples sent into Blackstone still stands good with many other top brands. I think don't stress and jump to conclusions about other weights of M1 (not 0w40) if you're not doing extended oil changes... say changing it under 4000 miles you're fine... Mobil-1 still have top notch anti wear additives in their oil.
Just my opinion of results I have been getting back from different vehicles.
#218
Originally Posted by SetoJai
I like this thread. Time sure goes by fast when you are reading and absorbing so much information. >.<
Which synthetic oils do you guys recommend for temperatures between -28 in the winter to +32 in the summer? I hate the Calgary weather, it flutuates so frequently.
#220
Originally Posted by geronimomoe
How about the Mobil1 EP 5w-30? Any numbers with that oil?
Regular Mobil 1 5w30 oil with 3500 Miles and the sample was still plenty good. Blackstone says I could go another 1000 miles if I like since the TBN was at 3.5. My car is supercharged so if you're NA, it would probably be fine for longer.
I'm trying 0w40 (with the longlife ratings / Group IV) and see if its all hype or do I have a higher TBN at the end of its use. So far, like I guessed, Mobil 1 is still great oil even if its not a true Group IV.... seems more important just to do your oil change at normal intervals!
#221
Originally Posted by FiveSeven SS190
EP? Not sure if I have seen that one... is it for "extra protection"? Well, if it has the MB and BMW ratings than its a group 4. However, I just got my results back from Blackstone Laboratories for
#222
I'm not sure if it's a Group IV. Might be just a Group III on mega steriods.. I might post at BITOG and ask the question.
#223
been using M1 silver cap with oem filter/washer the last 4yrs. no issues
for me. my G's only driven about 5k miles a year so i only change the
oil once every spring.
same thing on my 03 cooper-s. no issues.
it's good to be sensitive about oil if you're running superchargers/turbo's
i guess on track, but not sure if you need to be that sensitive on conventional
engines and normal/spirited street driving.
#225
Originally Posted by TurK
What you guys think about the Castrol Syntec 5w30?
Aren't we supposed to use 5w30...as it states on our manual?
As a side note, the 2nd # is the more important one if you live in a temperate climate. The first # refers to the oil's viscosity when the oil is cool, whereas the second number refers to the oil's viscosity when the oil is at or around operating temperature.
