DIY Cam Position Sensor Easy Version
Old May 5, 2012 | 11:29 AM
  #151
cvipgo's Avatar
Originally Posted by Silver tiburon
I agree. Thanks for the picture and the helpful post. I have edited the start page and updated the information there.
P0340 (Bank 1) Camshaft position sensor -passenger side
P0345 (Bank 2) Camshaft position sensor -driver side
Old May 9, 2012 | 06:59 PM
  #152
Cash169's Avatar
Thanks I'm.running my car MD for problem code now.n
Old May 12, 2012 | 09:22 AM
  #153
Daehtihs's Avatar
This may be redundant, but when I replaced my passenger side cam sensor, I found it may easier to use a 10 mm wrench vs. a 10 mm socket.
Old May 16, 2012 | 01:23 PM
  #154
JaE35's Avatar
Moderator
G35 Sedan
i've re-linked the image looks like it went down
http://img155.imageshack.us/img155/8504/blockrear.jpg
Old May 17, 2012 | 09:17 AM
  #155
Silver tiburon's Avatar
Image is repaired and back up. Thanks for the heads up.
Old May 23, 2012 | 08:07 PM
  #156
kkemmerich's Avatar
Just replaced my driver side cam position sensor on my 2003 G35 sedan because I had the P0345 error code. Initially I was getting the usual symptoms for that code so after I replace it and reset the ECU my dash is still it up... and my idle is jumping up and down. Basically it made it worse. Anyone have any recommendations? Lights that are on are: VDC OFF, SES, and SLIP.
Old May 23, 2012 | 08:55 PM
  #157
saywat?'s Avatar
^whered u get the sensor from?
Old May 23, 2012 | 08:58 PM
  #158
cvipgo's Avatar
I would have replaced both sides (passenger & driver) with OEMs not after market, generally one goes than other one will too...:How did you reset the ECU?
Old May 23, 2012 | 09:00 PM
  #159
kkemmerich's Avatar
I bought the sensor from Advanced. I reset the ECU using the throttle peddle method.
Old May 23, 2012 | 09:59 PM
  #160
kkemmerich's Avatar
More details:
Before replacing anything the car would occasionally hesitate during acceleration but no lights were on the dash. It started to become more frequent and yesterday the hesitation occurred and the SES, SLIP and VDC OFF lights all come on. Went to Advanced where I scanned the P0345 code and bought a driver side cam sensor. This brings us to today.
Today I get home no problems, the car hesitated maybe once on my way from work but when I get home I install the sensor/reset ECU and fire her up all the lights come on. Idle is now sporadic and acceleration is practically non-existent. It acts like the RPM limiter is set to about 2300 rpm's. Haven't had a chance to get it scanned again either.
Since replacing the driver side sensor made it worse I don't think replacing the passenger side sensor would help either... Is it possible that my oem sensor was shot and Advanced's part was even worse?! That doesn't seem likely. From what I have read the throttle body is another thing that causes this type of behavior. Should I give that a cleaning? Or does that not make sense for my problem?
Old May 23, 2012 | 10:02 PM
  #161
saywat?'s Avatar
after my issues with sensors from orielys i will only used oem sensors
Old May 23, 2012 | 10:12 PM
  #162
kkemmerich's Avatar
That's the answer I was both dreading and expecting. I already paid for one Advanced sensor that isn't returnable but has lifetime warranty... I could keep exchanging until one works I guess. But I feel like there is something else going on here besides the driver cam sensor.
Old May 23, 2012 | 10:17 PM
  #163
saywat?'s Avatar
^jus tell them its making ur car worst and they might take it back. i tried 2 sensors from orielys cus of the lifetime warranty exchange before i figured out somethings up with their sensors. bought oem one and everything worked perfectly.
Old May 24, 2012 | 01:04 AM
  #164
JaE35's Avatar
Moderator
G35 Sedan
It's been said many times in this thread. Our cars hate those sensors
Old May 24, 2012 | 01:10 AM
  #165
saywat?'s Avatar
Yea I'm getting tired of repeating my experience . People need to start reading this entire thread. It's only 11 pages lol
You have already rated this thread Rating: Thread Rating: 6 votes, 5.00 average.
