DIY Cam Position Sensor Easy Version
Rating: Thread Rating: 6 votes, 5.00 average.
Old Apr 16, 2013 | 02:22 PM
  #226
one2nite's Avatar
Update: im changing the knock sensor and harness that miketyler posted. my garage diagnosed it and said its a 300-400$ job. My original problem was the camshaft sensor bank 2. I replaced it and the car was fine but the 3 lights soon returned with the same p0345 aswell as the p0327 knock sensor code. Hope this helps its been such a headache.
Old Apr 16, 2013 | 05:56 PM
  #227
239g35's Avatar
you dont even have to take out the throttle body, its very easy to go around the plenum neck and do it thru there, i just did it in 5 min ( bank 2)
Old Apr 16, 2013 | 07:17 PM
  #228
Muski_G's Avatar
Went to autozone and it threw 0340 so its the passenger side apparently (bank 1)
Im going through infinitipartsusa.com and am confused which part exactly i need...item 6 right side or item 8 for the crankshaft. Trying to go off their picture too but not 100%
Any thoughts? Im thinking it should be the camshaft right side so item 6
Old Apr 17, 2013 | 11:16 PM
  #229
G35Outlaw's Avatar
Yes I just had to do all of mine I rather just do both and so to help prevent it from happening again replace crank sensor as well .. And I did all mine in like 20 minutes it was simple and never removed anything but the part there self .. Car runs great now !!
Old May 1, 2013 | 11:18 AM
  #230
one2nite's Avatar
So they changed the knock sensor and harness. Car was fine for 10 minutes then the vdc abs check engine came on again. Brought it back to the garage AGAIN. Now its only p0345 but i already changed bank 2 a couple months ago. Am i wasting my money to change it again? O well will find out soon... biggest nightmare ever cant wait to sell the POS car
Old May 1, 2013 | 12:05 PM
  #231
dj714's Avatar
I haven't changed as many parts as you have but my local shop ask me to take it to the leadership and have them run some kind of oil test to see if any ports/passages are clogged on the bank 2 side of the engine after speaking to my local autozone manager (former Nissan tech) he recommended running an oil/engine flush and swing if that would work before trying anything else.
Hopefully will get a chances this weekend and will keep you posted.
Old May 1, 2013 | 12:58 PM
  #232
Muski_G's Avatar
About a week after I posted this the check engine light went off. My engine only "struggled" to start one time (the initial time) and since then everything seems fine and no lights. Should i just go ahead and purchase it?
Here's the link to infinitipartsusa.com for reference, still not sure which item/part i'd need
http://www.infinitipartsusa.com/2005...tm?searching=Y
Old May 1, 2013 | 03:42 PM
  #233
one2nite's Avatar
Thanks let me know! the garage just called me, they changed the bank 2 sensor again and they took it for a 10 min drive and said it was running good. Will see how long this lasts...
Old May 1, 2013 | 03:46 PM
  #234
saywat?'s Avatar
^did u use oem or aftermarket sensor for bank 2?
Old May 1, 2013 | 04:11 PM
  #235
dj714's Avatar
Used both and had the same result
Old May 1, 2013 | 04:12 PM
  #236
saywat?'s Avatar
when i had to do the passenger side sensor i first used orielys sensor but i had issues with it. replaced with oem and it was good after that
Old May 2, 2013 | 09:59 AM
  #237
one2nite's Avatar
yes used oem aswell
Old May 2, 2013 | 10:27 AM
  #238
saywat?'s Avatar
yes used oem aswell
The first time u changed it n it was giving u issues was OEM sensor or aftermarket?
Old May 2, 2013 | 10:38 AM
  #239
Muski_G's Avatar
just called my local dealer to see if they had the part in stock, and he's telling me there are 4 sensors......2 on each side? Then he goes on to say they are clogged up because I dont change my oil enough though i just did a month ago.
I thought there were only 2 sensors?
Old May 4, 2013 | 09:02 PM
  #240
miketyler's Avatar
SayWat - you used the Oreillys and still had code and replaced with OEM and put out SES light? I still have SES light. Have changed passenger cam pos sensor (after market) and the dreaded knock sensor and harness but now have a new Intake valve timing code (IVT) P0011.
I am ready to step up to buy an OEM sensor but I would have figured someone here could confirm that they replaced the cheapie CPS with an OEM to resolve a P0011 code.
You have already rated this thread Rating: Thread Rating: 6 votes, 5.00 average.
