DIY Cam Position Sensor Easy Version
Rating: Thread Rating: 6 votes, 5.00 average.
Old Sep 30, 2015 | 11:59 PM
  #346
saywat?'s Avatar
Originally Posted by vq35dedriver
Damn are you not a belieber lol, I called infiniti of Tacoma at fife, nissan of the east side, auburn nissan and kuni infiniti..... do you want their numbers too?? All located in washington state
Every dealership and state provide different prices, that's why I was originally going to go with OC infiniti but I needed my car up and going and would not risk driving it with a bad sensor not knowing when my car would breakdown. I know my buddy that works at a local distributor for centric, stop tech and others and he also carries other parts. Sold me the sensor for $1 over their cost for the part.
My post was more for whomever needs to do this that they do not need to remove everything like originally posted. But do as you wish. Good luck to everyone.
One last thing Tian your base on clash of clans sucks bawls..... hahaha I'd wreck you lol
bc im bored i jus checked infiniti at tacoma's parts site online one sensor is $100 the other is $90. maybe they jus dont like u
Old Oct 1, 2015 | 06:38 PM
  #347
vq35dedriver's Avatar
Originally Posted by faiz23
First...i need your buddies contact info so I can get some parts for a $1 over cost. I need powerslot rotors, stoptech pads and lines along with stoptech fluid.
Second...where is this clash of clans base you speak of?...post pics
Haha, I used to have front stop tech st40 BBK. Sold it awhile ago, that I purchased from him under 1k. I'll post a pic of Tian base..... or you can visit him... he's in the clan Caedite Eos... his name in unknwn
Old Dec 25, 2015 | 05:04 PM
  #348
Digitalman1961's Avatar
Exclamation Help Needed
I am in the process of changing the bank 2 cam position sensor and really messed up. When I attempted to disconnect the harness from the sensor, I pulled the 3 wires out of the connector. I don't know which wires go into each of the slots. There is a yellow, black, and a red wire. Any help would greatly be appreciated!
Old Jan 26, 2016 | 05:20 PM
  #349
sunny81's Avatar
Thumbs up Error code is Bank1, should i change both camshaft sensors?
Hello,
I got an error code for Bank 1 camshaft sensor. Is it ok if i change just the one or should i change both the Camshaft sensors?
Also how often does the Crankshaft sensor go bad? TIA
Old Jan 26, 2016 | 05:23 PM
  #350
Urbanengineer's Avatar
Hello TIA.
I replaced one at 110k, and have the other in the trunk. Waiting till it fails.
120k/11 yr on my G and the other bank or the crankshaft sensor have not failed.
Old Jan 27, 2016 | 12:19 AM
  #351
saywat?'s Avatar
I change when needed
Old Jan 27, 2016 | 02:13 PM
  #352
sunny81's Avatar
Hello TIA.
Thanks for the reply.
Which one did you change at 110k? Bank 1(Passenger Side) or Bank 2(Driver side)?
Is it true that most of the times, it is the passenger side which goes bad?
Old Jan 27, 2016 | 05:40 PM
  #353
Mine was the drivers side.
Old Apr 26, 2016 | 06:42 PM
  #354
JDLu's Avatar
Well, we have a 2005 G35x .. about 120,000 miles .. it now takes longer to start – cranks about 3-4 sec where it USED to start immediately. It turns on the 3 dash lights and gives a code of P0340. (I have a code reader) I can clear the code, and it starts the same WITHOUT the “Check” lights ONCE … but the code is there … it has to have TWO starts – or RARELY it will “shudder” or cut out for an instant – and THEN set the check lights.
I DID order a Camshaft Position Sensor online and install it. The passenger side one – with the straight connector. Not a hard job at all, except that I have big hands.
THE PROBLEM … is still exactly the same ?? Seems exact symptoms !! So could the new sensor be bad? In the same way? OR am I reading stuff wrong and did I change the wrong one??
*** I DID see all sorts of prices on Camshaft Position sensors !! $137 at the Infiniti store to as cheap as $15 online !! I got a $35 one from A1Auto.com. JD
Old Apr 26, 2016 | 06:47 PM
  #355
The_Silencer's Avatar
I bought some Rock auto sensors because they were cheap. Ended up with the light returning and at worst the car not starting. If you have a cam sensor issue, You absolutely MUST by the sensors from Nissan, you cannot cheap out with these cars from my experience.
Old Apr 26, 2016 | 07:46 PM
  #356
saywat?'s Avatar
Most OEM sensors are about $90.
Old Apr 26, 2016 | 09:29 PM
  #357
GreenPenguin's Avatar
Yup! Pay now or pay later.
Old Apr 28, 2016 | 02:41 AM
  #358
JDLu's Avatar
Well, re my post of 4-26 … where the NEW ($35) sensor didn’t work. My bad !! In 2 or 3 places people discuss the damn green connector. I had broken that a little in getting it off – and there was a piece of plastic keeping it from seating fully (there’s a rubber gasket in there) and making good connection. I pulled the new sensor out and measured resistances compared to the old bad one … there IS resistance in the new (GOOD) one. Had to use a small and sharp pair of dikes and “chew away” the broken part of the green connector. NOW it plugs in fully !! (I used a few wraps of Scotch 88 electrical tape to seal and hold in place) THEN – with the connector in place, I was able to get the CPS back in. (Real easy after you’ve done it 3 times !!) Cleared the codes, crank her up and starts immediately. Runs fine – with the $35 sensor from A1auto.com. JL
Old Apr 28, 2016 | 02:49 AM
  #359
JDLu's Avatar
Originally Posted by Azhreal
This is why computer people don't work on cars, just dropped the 10mm wrench I just bought down behind the motor and now need a long magnet to get it back. Can't drive the car til then. This is exciting.
Well you learn things. I just did mine (multiple times). I use a small wire -- like 24 ga "phone wire" -- 2 or 3 feet long. I've worked in the air -- Radio towers and such -- and you learn to tie your tools off so that if - when you drop them you can just reel them in.
Same with the little 10 mill bolt. Wrap that with a fine wire 5 or 6 wraps -- get it started in a ways and unwrap the safety wire. JL
Old Aug 4, 2016 | 05:26 PM
  #360
helalo's Avatar
my mechanic said my G35 has 4 camshaft sensors, 2 on each side.
i called infiniti dealer to check and told me the same thing.
manual g35 has 4 camshaft sensors.
automatic g35 has 2 camshaft sensors.
You have already rated this thread Rating: Thread Rating: 6 votes, 5.00 average.
