DIY Cam Position Sensor Easy Version
Old Apr 19, 2012 | 02:43 PM
  #121
s_lloyd_s's Avatar
Ohhhh it'll "CLICK" when the green release spring tab is pressed in far enough!?!?
Old Apr 19, 2012 | 02:44 PM
  #122
s_lloyd_s's Avatar
Ya thats what I was asking before. If I could undo the bolt then pull the whole senor out and THEN detach the connector from the sensor.
  #123
saywat?'s Avatar
when u push it all the way itll click and stay there in the unlocked position. when u put the sensor back on push it together as tight as u can and the green tab will click again and move back into the locked position.
Old Apr 19, 2012 | 02:45 PM
  #124
s_lloyd_s's Avatar
Great to hear!!!! Thanks that should help me out a lot!
  #125
saywat?'s Avatar
yea u can do that.
Old Apr 19, 2012 | 02:48 PM
  #126
s_lloyd_s's Avatar
Any advice on the other sensor? If i had the code for the passenger side one and I'm replacing it now should i just go ahead and replace the driver side one too while Im at it or just wait for it to fail in however long that will be?
Old Apr 19, 2012 | 02:52 PM
  #127
saywat?'s Avatar
some people will say change both. some say change as it breaks (dealer and infiniti riverside suggestion). ive only had to change the pass side. i changed mine in oct.
Old Apr 19, 2012 | 02:55 PM
  #128
s_lloyd_s's Avatar
Alright, I'll just wait and save my money. Thanks
Old Apr 19, 2012 | 04:14 PM
  #129
Trickstyle's Avatar
I ended up changing both of mine, in CA autozone cant do free OBD-II scans, so since I didn't know which bank was failing, I just said f*** it n did em both. I was tired of my engine dying on me constantly...
Old Apr 19, 2012 | 05:14 PM
  #130
saywat?'s Avatar
^coulda gotten the code urself the old fashion way. the code will say specifically which bank to change
Old Apr 19, 2012 | 05:15 PM
  #131
s_lloyd_s's Avatar
Whats the old fashion way of coding the G35?
Old Apr 19, 2012 | 05:17 PM
  #132
saywat?'s Avatar
http://www.nicoclub.com/archives/alt...s-cel-ses.html
This article shows you how to read/pull the fault codes, usually accompanied by a Check Engine Light or Service Engine Soon, on your Altima with push button start. You do not need an OBDII code reader or any other special tools to do this.
To take a reading without using an OBD II reader, you can do this:
Note: Familiarize yourself with the entire procedure before attempting. A pen, paper, and stop watch will be helpful.
1. Put the car into “ON” without the engine started (hit the ignition button twice without having your foot on the brake)
2. Wait 3 seconds for the car to do a systems check (you know this is done when all the lights except your service engine light go off)
3. Do 5 full accelerator press and releases in 5 seconds (floor your car 5 times in 5 seconds)
4. Wait 7 seconds.
5. Floor the accelerator again, and hold it there for 10 seconds (approx).Your service engine light will turn off.
6. When the light turns off, take your foot off the pedal, and get ready to count.
At this point, the service engine light will start blinking.It will give you a 4 digit code – the first number will flash slowly, followed by a slight pause, the next three numbers will flash quickly, all with a pause in the middle.10 flashes means a number “0.”So if your car blinked 10 times, then 4, then 4, then 2 again, you would have a code of “0442,” which is your gas cap thing.Other codes can be determined by looking at a OBD II code reference sheet.
Old Apr 19, 2012 | 05:19 PM
  #133
JaE35's Avatar
Moderator
G35 Sedan
man did not know that was possible lol
Old Apr 19, 2012 | 05:25 PM
  #134
s_lloyd_s's Avatar
damn thats intense haha...its pretty close to the procedure of resetting the "check engine service" light i see
Old Apr 19, 2012 | 06:25 PM
  #135
saywat?'s Avatar
yup thats how i found my cam sensor error code
You have already rated this thread Rating: Thread Rating: 6 votes, 5.00 average.
