Stock motor with forced induction . . . how badly did you push it?
Old Sep 17, 2010 | 11:47 AM
  #271
eckoultd87's Avatar
Originally Posted by steven3313
05 6spd stock internals turbonetics kit w/ skunk 2 spacer 368whp and 371tq at 6.5psi tuned by motiva engineering... only 3rd day boosted....cold starts just fine but when its warm it kinda struggles on the start up is this normal? any fixes?
I believe its because of the bigger injectors. I'm guessing you're running Utec? if so Haltech will fix the problem.
Old Sep 17, 2010 | 11:59 AM
  #272
steven3313's Avatar
tune? if so its the uprev osiris. does your car do the same? he also said not to turn the boost up til i get new spark plugs, so maybe better spark plugs will help it start better?
Old Sep 23, 2010 | 12:50 AM
  #273
JayV35's Avatar
Sorry to disturb every one but im new and i have a 2003 g35 6mt. How much whp/wtq can i have with:
stock block
GTM TT kit (GT2871R .86AR)
APS 3'' High output cat back
GTM STAGE 1 CLUTCH & FLYWHEEL COMBO
and for sure lowered suspension
injectors? which one
I want 400-450whp on daily drive. is it possible with stock block and low boost?
Old Sep 23, 2010 | 02:42 AM
  #274
Sylvan lake V35's Avatar
It depends on what you call low boost 400-450whp should be easy with 7-10psi.
Old Sep 25, 2010 | 02:03 PM
  #275
JayV35's Avatar
Will I have to upgrade injectors or just put the exhaust, clutch and TT? Obligation to reflash?
Old Nov 1, 2010 | 09:36 PM
  #277
adamls2's Avatar
damn 490 on stock block??
Old Nov 17, 2010 | 09:06 PM
  #278
rcdash's Avatar
LOL. More like 390. Post the dynojet sheet with the boost curve or it didn't happen.
Old Nov 17, 2010 | 09:34 PM
  #279
djamps's Avatar
His dog ate the dyno sheet
Old Dec 22, 2010 | 11:51 PM
  #280
APSMike's Avatar
Please update mine. I changed my screen name from infinitiGTR2004 to APSMike.
14. APSMike - 2004 6MT Coupe - Daily Driver - APS TT - APS Plenum - 2.5" APS Test Pipies - Borla True Dual Cat Back - Zeitronix WB/EGT/BST - ACT HD w/Street Disc - KurumaZ Front Bumper - Installed @ 24K Miles by Me - 75K Miles on Boost (Still going strong) - Tuned once by JapTrix after install - 93 Octane - 446 RWHP / 403 RWTQ (dynojet) - 10 PSI - 12.09@115.9mph - 1.89 60' - BFG DR - 3,750 lb - 40+ passes down the 1320 Updated 12/23/2010
Old Mar 4, 2011 | 09:33 PM
  #281
prodigyG's Avatar
Cracked piston on a stock block after being tuned 6psi
362whp 331 wtq
Greddy Twin turbo upgraded 18g
Only 35,000 miles
Old Mar 6, 2011 | 10:31 PM
  #282
GeezNuts's Avatar
/\ damn... who did the tune, That isn't much boost to be cracking a piston... what is your game plan now?
Old Mar 6, 2011 | 10:52 PM
  #283
prodigyG's Avatar
Sound Performance in IL... Had it on the dyno to tune it. The tuner couldnt get a base map in time from greddy so he started from scratch on my emanage. Leaned it out heard a POP!! White/black smoke spewing! Put down decent numbers brought it to a buddy he check codes. Misfire cyl. 4. Brought car to Ams performance did a
Compression test . Cylinder 4 no good. The oil cap started hovering as it was loose during the test.
Ams performance 1st g35 fully built. Its together and it being final tune this week so i can pick up. Got me racelogic traction control and some 20'' DPE
ro5 variants patiently waiting
Old Mar 7, 2011 | 08:25 AM
  #284
g-adabout's Avatar
^ I blew the same piston and number 5 (I should say cracked them around the rings) from a bad tune as well in the beginning at 8psi after about 1500 miles...and by bad tune, I mean that the first tune was tuned to 6500rpms instead of 7000rpms. Minor mistake but made right. The Tune is everything!
Although I am still with a stock block, I am happy with the tune at under 6psi. I actually have a better torque curve and better numbers than I did prior on the first tune.
Update!!!
45. g-adabout - Stock block Turbonetics ST kit...threw out the crappy turbo and replaced it with a Garrett T3/60-1, UpRev Tune, HKS Exhaust with strait pipes (no cat or resonators) with an electronic cut out and injectors. 393whp and 352wtq at 5.5psi! <-final set up Also tuned at 8psi for 418whp and 378wtq but that tune would require a new MAF and Fuel Return upgrades. 6500 clean boosted miles now, several passes down the 1320. Sacrificed a few A/C lines and a lower radiator hose, but motor is still running strong.
Old Mar 7, 2011 | 08:47 AM
  #285
prodigyG's Avatar
Mine was tuned to 6500 instead of 7000 as well and mine also crack on the side by the rings. The shop took 0 responsibility. I went with the Cosworth 8.8:1 this time for a bit higher compression.
