FI: we're not in Kansas anymore...
Old Aug 2, 2011 | 08:04 PM
  #391
red35's Avatar
Originally Posted by ITNKICN
As for the quaife / tomei... thanks for the guidance gord- sounds like I've got some things to look into and consider. What I'd like is that stock feel until you hammer on it.
I know i was looking into LSD's as well. I was getting talked into the Tomei as well. But after doing some search i would have to agree with Gord and get the Quaife. Tomei are a clutch style in which people say you can make a lot of noise and the quaife is almost like stock.
Good to hear the car is alive. It will be nice to see this thing when it is all broken in and tuned up.
Old Aug 2, 2011 | 10:36 PM
  #392
Eno's Avatar
Eno
I've been doing my reading and everything I'm seeing is suggesting the Quaife... What I'm being told by the shop (who deals with both) is that while both make some noise- the Quaife is more noticeable than the Tomei. We're going to continue looking into it but from what I'm reading and from the suggestions in here- Quaife is definitely looking like the choice.
Also, it was said that while the Tomei may need to be "rebuilt" occasionally, the Quaife would need more maintenance. Again, not what I'm reading (basically same maintenance schedule as stock) but you know what they say about reading on the internet... believe everything you read, and you better not read.
It's tough too- you get a guy who spends 1400 bucks on the automatic version of the quaife and ask him if he loves it... well, of course he's going to love it... that's a lot of money plus install unless he does it himself. A small percentage of people will go in and say "yes, I totally wasted my money-" at least not until the next best thing comes around. "Yes, what I'm using now rules and what I was using sucked."
Objectivity seems to be inversely proportionate to the amount of money and time spent.
I also talked to them about my issues around the fluttering throttle and they said there's a good chance it is just that gasket is kaput. I'll replace that when I get back to Van and see where it goes from there.
In addition- wanted to try posting some photos!
Attached Thumbnails FI: we're not in Kansas anymore...-img_0732.jpg   FI: we're not in Kansas anymore...-img_0733.jpg   FI: we're not in Kansas anymore...-img_0736.jpg   FI: we're not in Kansas anymore...-img_0738.jpg   FI: we're not in Kansas anymore...-img_0751.jpg
Old Aug 2, 2011 | 10:42 PM
  #393
seymore4's Avatar
m56
looks so good in the sun
Old Aug 3, 2011 | 07:28 PM
  #394
Sylvan lake V35's Avatar
Quaife makes zero noise and needs zero maintenance aside from regular oil changes and it does not require extra additives to the oil like clutch style ones.
Looks like they have a direct drop in for your car as well
http://www.quaife.co.uk/shop/products/qdf10l
Hear is more on the different styles of Diffs
http://www.tomei-p.co.jp/_2003web-ca...x-ad_rset.html
Old Aug 3, 2011 | 08:50 PM
  #395
Eno's Avatar
Eno
I continue to lean towards quaife... Thanks for the links gord.
Old Aug 3, 2011 | 08:57 PM
  #396
Gdriver90's Avatar
ian - love the new sig. HAHA AWEsOME!
Old Aug 3, 2011 | 09:58 PM
  #397
Swivel's Avatar
Moderator
She's looking good, Vern!
Old Aug 4, 2011 | 09:55 AM
  #398
Eno's Avatar
Eno
Eh guys... well here is a couple photos of my current issue. This is the location of our fuel pump under the passenger side rear seat. As you can see there is a pretty substantial stain from leaking fuel under there and some moisture (fuel) on the top of the fuel pump. Looks like badness to me!
Anyway, turns out the part I need is 7 bucks from Nissan (notice the X next to the O ring? Yeah, that one)- maybe a bit more. Looks like a quick fix judging by the FSM.
Any tips or tricks with the install / removal?
Attached Thumbnails FI: we're not in Kansas anymore...-img_0760.jpg   FI: we're not in Kansas anymore...-img_0761.jpg   FI: we're not in Kansas anymore...-img_0763.jpg   FI: we're not in Kansas anymore...-fuel.jpg
Old Aug 4, 2011 | 11:15 AM
  #399
Gdriver90's Avatar
when did u repaint your car pink?
Old Aug 4, 2011 | 12:57 PM
  #400
Eno's Avatar
Eno
Must have left it out in the sun too long...
Old Aug 4, 2011 | 01:39 PM
  #401
djamps's Avatar
Get a new o-ring... common issue
Old Aug 4, 2011 | 06:10 PM
  #402
superchargedg's Avatar
Dont let the oring get wet with gas as it will expand.
Old Aug 4, 2011 | 06:25 PM
  #403
Did you run the car with the top off like that? Make sure it is not the lines leaking???
Old Aug 4, 2011 | 08:07 PM
  #404
Eno's Avatar
Eno
I'm going to run it a bit more when I get back out there so that I can actually visuallize what's going on back there- and ensure it's the gasket (which I'm going to replace anyway).
I'm 99% sure it's the O-ring but to be honest I didn't have a lot of time before I left to mess around. Well, not with the fuel system anyway! Priorities.
Old Aug 5, 2011 | 04:48 PM
  #405
Eno's Avatar
Eno
Okay boys- well true to form I have done some research, got loads of feedback and have pulled the trigger on the Quaife. I'm on that Vancouver Island Poker Run on the 20th so I'm going to hope to get it done before then. With that being said, the car isn't exactly limping around either (well, other than that stupid O ring thing) so I'm sure I can survive without it. Then again, I figured I might be able to survive without going FI and we all know how that ended up.
So thank you again for the feedback and the IMs. I think we've made the right decision!
