APS Extreme Twin Turbo Build
Old Mar 11, 2012 | 01:16 PM
  #91
RADRaze2KX's Avatar
Awesome thread. Keep us posted and good luck with the latest obstacle.
Old Mar 13, 2012 | 11:13 AM
  #92
o__O's Avatar
Good news. EVT control position sensors and EVT magnet retarders were swapped out and the timing has smoothed out. Now trying to trouble shoot engine knock at 12 psi. Running one wide band O2 on the driver's side bank. Its possible that we are lean in one or more cylinders on the passenger side (or even the driver's side...). Fuel pressure is good so the injectors are going to get pulled and tested.
Howard @ Technosquare, Shawn @ Church, and Marty have been working hard to help me get everything dialed in. More updates to come.
Old Mar 13, 2012 | 01:53 PM
  #93
Lone Wolf's Avatar
^ Glad to hear.
Old Mar 13, 2012 | 02:20 PM
  #94
Eno's Avatar
Eno
Originally Posted by str8dum1
^fitment looks poor at best. whats with teh gap between the bumper and the hood?
Not to draw away from the other developments but to respond directly to the fitiment on this style of bumper... unfortunately I think that's pretty standard for the one piece. I know my K2 was like that and when I was whining about my fitiment people were telling me it was the norm.
I've since moved to a two piece setup- including the poly KZ and the fit is MUCH better.
OP... you've put in SOOOOOO much work here- you owe it to yourself to improve on that front setup.
Old Mar 28, 2012 | 06:58 PM
  #95
o__O's Avatar
final #s are in...
572whp @ 12.5 psi
620whp @ 15 psi with 50% 100 octane and 50% pump gas
Old Mar 28, 2012 | 07:13 PM
  #96
g35pillow's Avatar
Damn sick numbers congrats
Old Mar 28, 2012 | 07:16 PM
  #97
alfhasg35's Avatar
nice numbers bassam.. that thing is a beast..!!!
Old Mar 28, 2012 | 07:19 PM
  #98
Silencer_0's Avatar
Sick power man, congrats!
Old Mar 28, 2012 | 07:27 PM
  #99
CandlestickPark's Avatar
ill Sedan
Wow, congrats man!
Old Mar 29, 2012 | 12:49 AM
  #100
350Z T's Avatar
Wow, 100whp (16%) difference between a Dynapack and DD with identical kits, and boost pressures:
http://my350z.com/forum/forced-induc...-complete.html
Old Mar 29, 2012 | 11:39 AM
  #101
o__O's Avatar
I came across Glex25's thread here on driver before. His car is a beauty! I don't think anyone here doubts that there are differences between readings from dyno to dyno. Or even pulls on the same dyno from day to day with the same car. A dyno is just a tuning tool.
https://g35driver.com/forums/forced-...-complete.html
Old Mar 29, 2012 | 12:01 PM
  #102
350Z T's Avatar
I agree 100%.
Old Mar 30, 2012 | 11:16 PM
  #103
silver g's Avatar
Nice Bassam!! Looks like you got everything sorted out bro! I want another ride!
Old Apr 1, 2012 | 11:00 AM
  #104
dreamweaver's Avatar
Nice write up.. as im thinking of this turbo set up on a 4.2 GTM Darton sleved block with cams and nice heads.. Id be curious as to what it will make for power... I will be selling my supercharger set up soon.
Old Apr 1, 2012 | 11:36 AM
  #105
o__O's Avatar
if you're considering the APS Extreme setup get the bigger injectors Rob had mentioned. At 14.5-15 psi there was still a cushion for the injectors but I can't imagine they would keep up if you really crank up the boost. I'm really happy with the way everything turned out because we still have a cushion for the MAF as well at this power level.
Sounds like you're gonna be building a monster
