Vortech SC in a 5AT
Old Oct 30, 2005 | 11:28 PM
  #46
g8tor20's Avatar
FGC's official flip flopper
I do have an 05. Yes...raising the idle will fix it b/c the sound goes away as soon as you tap the gas. But...I did the L-spec and avoided the F-spec b/c I didn't want anyone messing with the fuel or timing maps (outside of the the SS box). If they can easily raise the idle...then maybe I'll do that. I have to figure something out.
Old Oct 30, 2005 | 11:59 PM
  #47
Mr_pharmD's Avatar
ya, call Brian at TS and he can upgrade your L-spec to the F-spec for a cheaper price. I really want to know if this option is worth it.
Old Oct 31, 2005 | 12:21 PM
  #48
jsal's Avatar
I have to admit, I've been able to quiet it down alot but it still does exists at the low idle. Unfortunatly, having an early '03 I here raising the idle isn't an option. I would be nice if Vortech did address this issue
Old Oct 31, 2005 | 12:54 PM
  #49
Dan_K's Avatar
'03's can raise the idle. If you production is later than 10/03, then you can't. I'm pretty sure this is correct.
Old Oct 31, 2005 | 01:21 PM
  #50
g8tor20's Avatar
Dan is right. The early builds can raise the idle. It's the newer guys that can't do it. (they can do it by tinkering with the timing but eventually it returns back to low idle)
Old Oct 31, 2005 | 02:55 PM
  #51
jsal's Avatar
Is this something anyone can adjust or does it need to be reprogramed thru the ECU?
Old Oct 31, 2005 | 03:03 PM
  #52
g8tor20's Avatar
dealer does it
Old Oct 31, 2005 | 03:14 PM
  #53
jsal's Avatar
Well I guess it's as quiet as it's going to get... At least until I need to see the dealer for something else, especially if it resets itself.
Old Oct 31, 2005 | 03:16 PM
  #54
Mr_pharmD's Avatar
Thats not true.. TS F-spec reflash can raised the 05 idle to anything u want them to.
Old Oct 31, 2005 | 03:19 PM
  #55
g8tor20's Avatar
I was referring to non-ECU reflashes. On post 10/03 models, the dealer can only tinker with the timing. TS can pretty do anything they want with your fuel/timing maps.
seagrasser
May 3, 2022 09:43 AM
StreetStandard
Engine-Vendor
117
May 22, 2020 08:21 AM
Gwhut?
Drivetrain
Sep 6, 2015 10:07 AM
TrillO.G.35
Sep 5, 2015 02:06 AM
n2fooz
Sep 4, 2015 07:46 PM
