G35 & G37, Coupes & Sedans
***update on my MAZDA flip key FOB mod. alternative to nissan key fob.
Old Sep 14, 2006 | 05:57 PM
  #61
oscottio's Avatar
Originally Posted by Aznteazer
how did u guys open up the mazda remote?
flip out the key and look inside where the key was, there's a small area where u can push in with a pin or something sharp and pull out(at the same time) the part that has the button to flip out the key.(top half). to open the top half, you need to take off the mazda logo (it's on there with a double sided tape) and u'll see a screw. be careful after that cuz there's a spring loaded mechanism that flips out the key.
as for the bottom half, you just need a small screw driver to take the halves apart.
Old Sep 14, 2006 | 06:34 PM
  #62
G35DORME's Avatar
"It’s never enough”
What’s up guys ok so I showed this thread to my friend and he said he can do it no problem (he is good w/all this kind of stuff) but I have been looking on eBay and can’t find an uncut RX8 fob
thanks
Old Sep 14, 2006 | 07:11 PM
  #63
KiDFuZioN's Avatar
thanks
You don't need an uncut keyfob since you can't use the key anyways. To get the key to fit you need to have someone cut the head of the infiniti key so that it looks like the mazda key and you put that key into the key fob.
Old Sep 14, 2006 | 07:49 PM
  #64
accordfreak's Avatar
if you have a dremel, you could do that also.. I was asking all over the place here and they all said no.. so I busted out the dremel. works fine.
Old Sep 14, 2006 | 07:56 PM
  #65
oscottio's Avatar
same here..i used the dremel to shape the key.
Old Sep 14, 2006 | 08:32 PM
  #66
KiDFuZioN's Avatar
You could also use a grinder if you had one but I just had a locksmith do it for me for $25.
Old Sep 14, 2006 | 10:34 PM
  #67
Aznteazer's Avatar
friend with rx8 said u shouldnt put many keys on it. some kinda alarm goes off on his car.
just a fyi.
Old Sep 15, 2006 | 12:09 AM
  #68
oscottio's Avatar
holy crap batman!
Old Sep 15, 2006 | 12:23 AM
  #69
just a fyi.
huh? the mazda board isn't used.
Old Sep 15, 2006 | 12:26 AM
  #70
oscottio's Avatar
yeah, it shouldn't affect us cuz we're using a far superior nissan..i mean infiniti board.
Old Sep 15, 2006 | 12:37 AM
  #71
Aznteazer's Avatar
cuz of the weight hanging on the key i guess since it has more leverage. nothing to do with the chip.
Old Sep 15, 2006 | 12:21 PM
  #72
Clemmdog's Avatar
I was just looking at Mazda key fobs... from what I can see the one that looks like the one you used is a 3-button (no trunk). Is this true, or have I not found the right fob yet?
Old Sep 15, 2006 | 12:32 PM
  #73
oscottio's Avatar
there are 2 types of mazda flipkey/remotes, a 3 button and 4 button. the remotes look identical. we used the 4 button one. you have to look carefully.
Old Sep 15, 2006 | 12:35 PM
  #74
Clemmdog's Avatar
Are you finding these on ebay or through other sites? Thanks.
Old Sep 15, 2006 | 12:44 PM
  #75
oscottio's Avatar
i found mine on ebay, but it seems like there's only a couple left on there. they want like $40 plus shipping used. good luck
