G35 & G37, Coupes & Sedans
Gas Gauge WEIRDNESS !
Old Jul 26, 2012 | 04:03 PM
  #226
GR6RR's Avatar
this way, you'll never run out
Old Jul 27, 2012 | 01:06 PM
  #227
Trickstyle's Avatar
Originally Posted by linedr89
my gas light turns on with i have 4 gallons left.
well i guess its better to have the light on with 1/5 of your tank than 1/10 lol
Old Jul 28, 2012 | 12:45 PM
  #228
Nismoali's Avatar
did anyone try this solution? please let me know. have the sameeeee problem . smh
Old Jul 28, 2012 | 12:49 PM
  #229
MaDMaXX's Avatar
What solution? the cleaning?
Yes, that's why we do it.
Old Jul 29, 2012 | 02:56 PM
  #230
Trickstyle's Avatar
beat me to it lol but yeah, the problem and solution has been figured out
Old Aug 3, 2012 | 06:18 PM
  #231
blAk mAx's Avatar
Just did mine, didn't really get too much dirt
Old Aug 3, 2012 | 09:51 PM
  #232
superman22x's Avatar
Well, I gave it a shot today. Cleaned the two sending units, and then reset the battery afterwards. Turned the car on and the gas gauge still reads about 1/4 tank too high... I'm going to fill up tomorrow and see if it adjusts after that.
Old Aug 3, 2012 | 11:52 PM
  #233
MaDMaXX's Avatar
Blak, you won't necessarily get much dirt off, but it does help.
superman, it doesn't sound like you have a dirt problem, at least, not anymore, sounds like it's actually faulty. Don't bother resetting the battery (whatever that means) it doesn't make any difference.
FWIW, i didn't even disconnect my battery to do this.
Old Aug 4, 2012 | 01:43 AM
  #234
blAk mAx's Avatar
seems like its reading correct now. definitely keep a rag handy when unplugging the fuel line. i was surprised when the gas spurted out. i disconnected the battery just in case.. filled up and added some gas/injector cleaner afterwards
Old Aug 6, 2012 | 12:16 PM
  #235
I reset the electrical system is what I meant, by unplugging the battery. Yeah, I am thinking the sensor is bad as well. It works ok, it's just off by 1/4 tank. I don't know which side is bad either, or if it's both.
Old Aug 6, 2012 | 12:45 PM
  #236
MaDMaXX's Avatar
You can run a multimeter on them and measure the resistance, it should be smooth.
Old Aug 7, 2012 | 02:29 PM
  #237
Any idea what voltages should be?
Old Aug 7, 2012 | 08:50 PM
  #238
MaDMaXX's Avatar
Resistances, but check the guide i posted, it should have a rough idea of what they were on the guys who wrote the guide.
Old Aug 9, 2012 | 08:59 AM
  #239
What guide did you post? And where?
Old Aug 9, 2012 | 09:09 PM
  #240
MaDMaXX's Avatar
Hmm, may not have posted it here.
http://www.madmaxx.myzen.co.uk/350z/...0FuelGauge.pdf
