G35 & G37, Coupes & Sedans
Gas Gauge WEIRDNESS !
Old Apr 20, 2011 | 01:43 PM
  #166
luvmyzx6r's Avatar
Instead of using Q tips, can I just spray it down with electronic cleaner?
Old Apr 20, 2011 | 03:04 PM
  #167
luvmyzx6r's Avatar
oh great.... :/ Just cleaned it and it still only fills 12 gallons and at the same time only registered at a little over half a tank on the gas gauge. Should have just left it the way it was.
Old Jun 24, 2011 | 11:33 PM
  #168
Cassman's Avatar
Did it today after living with it for about 4 years. Works and I feel like an idiot for not taking the 40 minutes to do it some time during the last 1200 days.
Old Jun 26, 2011 | 12:55 PM
  #169
T4RUSAF's Avatar
I can't tell if mine is fixed... I did this cleaning and now instead of 3/4 full at fillup I get the whole tank, but I am only averaging 14-15 gallons when my gas light goes on for the first time. the neck, filler tube, etc. has been replaced by the dealer in the past.
how many gallons should i expect to fill up after the the light appears for the first time?
Old Aug 3, 2011 | 03:30 AM
  #170
Trickstyle's Avatar
w/ my 2005 Z the light turned on at 32 miles left(no fuel pump problems)... with my G i think i marked it at ~36 miles after the light turned on. so approx 2 gallons left(reserve tank) and it'll turn on.
Old Aug 3, 2011 | 04:17 AM
  #171
Trickstyle's Avatar
my G has fuel pump problems :/ it seems to be caught on 2 "tracks" it will either be accurate from empty to just under half, or it will be accurate from full to half, and then sit at half until it gets low enough for the light to be on. but it wont drop to "E" with the light on until the next time i start my car lol so needless to say, i never fill it above halfway just to avoid it getting on that second "track" :/
Edit: Fixed...
Old Aug 3, 2011 | 10:22 AM
  #172
JacekPSUr6's Avatar
^ The picture has already been posted...like you said, stop being lazy, find the pic/instructions and get it fixed.
Old Aug 5, 2011 | 10:48 PM
  #173
Trickstyle's Avatar
my bad, i had gone right over it :/
Old Aug 6, 2011 | 12:33 AM
  #174
JacekPSUr6's Avatar
^ Page 6 - scroll down a bit for the pics:
https://g35driver.com/forums/g-spot/...irdness-6.html
Old Aug 10, 2011 | 12:22 AM
  #175
Deemo's Avatar
Originally Posted by davidxu
one: a full tank on my G35 reads 1/8 over full on the dash.
two: i can't put in gas properly, the pump will shut off intermittently even when gas tank is not full. Had everything but the gas tank replaced, nothing. Went to replace the gas tank, so far so good.
i have those exact same issues. I just pull the gas handle like half way and it doesn't allow it to do automatically stop pumping gas like is would as if it the tank is full.
Old Aug 30, 2011 | 02:25 PM
  #176
Trickstyle's Avatar
yeah, thats part from the gas cap to the tank itself. unfortunately, the whole tank needs to be replaced i hear. super shitty :/ that happened to me once, i had to pump it with the dispenser upside down, i looked like and idiot but it worked lol
Old Sep 2, 2011 | 02:30 AM
  #177
InfinitGman's Avatar
I'm having an issue with my gas tank as well:
I have to keep filling it up.
Is there a way to just fill it up once and it will stay filled... for like... forever?
***haha I had to
Ok, back on topic.
Old Sep 2, 2011 | 02:35 AM
  #178
beb's Avatar
beb
So glad I found this topic. My gas will read about 3/4 when I fill it up and just drop quickly and show empty by the time Ive used 6 gallons. lol. Must try this and crossing my fingers itll fix it!
Old Sep 14, 2011 | 10:19 PM
  #179
jutn35's Avatar
G35 Coupe
well i fixed this problem again, seems that it gets dirty every once a year . Im getting faster at doing this hahaha
Old Sep 16, 2011 | 12:54 AM
  #180
beb's Avatar
beb
I finally got to it today!
I wiped down the little circuit boards.... The QTip came out clean and I also got a new gas cap. I just drove the car and it may be too early to tell, but its at the accurate fuel level!
*tears of joy*
Mine was REALLY bad, recently its been showing empty after driving only 80miles! So I am ecstatic. I hope it stays this way!
Thank you to the thread and OP!
