One of the model actually likes the 350z a lot, i just said its the same car other than a backseat and a trunk lol.... thanks for the like man
I like looking at cars and I like looking at girls too. But I never understood why people put them together.
I dunno man. Kinda hard to focus on both. One grabs the attention from the other.
Its like trying to get some asś while watching a sports game. Cant do em both at the same time.
^Clearly you haven't learned to multi-task hahaha.
Fixed for you...….
Fixed for you...….
5AT guys can benefit from the 3.5 gears out of a 6MT equipped differential. There is also a 3.7 geared diff from newer 370Z's that will work but that's damned steep in the 5AT and renders 1st gear sort of worthless in the 6MT unless you are on drag tires with a sequential transmission.
The 3.7 from 370Z is a decent option. It's not dramatic enough to make 1st useless, especially considering our 6MT uses the exact same gear ratios as the G37/370Z. Oh and 07-08 G35 sedans had the 3.7 ratio matched to the 5AT.
Another decent option is a 3.9, depending on your track day needs. Haven't seen any higher than that used on this platform. Maybe the drift guys get into the 4.x ratios.
Fixed curb rash and plastidipped wheels gold
Goes well with the overall asthetic of my shitbox IMO
I know, I know, the quarters are still plastidipped from the rust repair. By the time I get around to properly fixing it they'll be rusted out again
One owner 2004 G35 Coupe 6MT
I never had that issue. I'm not sure what you mean by pulling the leather up, is there some sort of aftermarket chilling pad? The OEM implementations I've seen are of the ventilated type, where there is ducting and a fan that draws air through the perforated seating surfaces.
