G35 & G37, Coupes & Sedans
Old May 10, 2019 | 09:44 PM
  #9676
LoSt180's Avatar
My clear bumper lights were clipped in and haven't been messed with in 8 years. Odd so many of you need screws and zip ties to hold them in.
Old May 10, 2019 | 09:50 PM
  #9677
herrschaft's Avatar
I have an aftermarket bumper which is thicker than OEM, the clips don't work very well with it.
Old May 10, 2019 | 11:12 PM
  #9678
Spitting Llama's Avatar
Sedan, 5 speed automatic, Rear wheel drive, SPC A arms, Stillen cold air intake
I was reading an old thread today about the throttle opening around 80% instead of 100% and got an idea, I decided to check the APP sensor for the answer to this problem and noticed it wasn't going through its full travel, It had adjustment screws so i adjusted it full counter clockwise so it was at the full beginning of its limit, but now it had an operating range bigger than the range of the pedal bar so i increased the pedal travel by bending the bar level with the brake so that the stop off the back of the pedal contacted the firewall just before the stop in the APP sensor contacted, the other option was to cut the stop off the back of the pedal but i decided it was too permanent and wouldn't permit proper adjustment nor operation. It worked I now have a much farther pedal travel and a noticeable power increase. If someone with a tuner or access to a dyno wants to try this and could verify the throttle travel and/or power increase that would be great.
Old May 11, 2019 | 03:05 AM
  #9679
Scorpi0's Avatar
I want more info on this. I could use some free extra power.
Old May 11, 2019 | 08:17 AM
  #9680
What do you need to know?
Old May 11, 2019 | 10:13 AM
  #9681
Scorpi0's Avatar
Does being able to push the pedal further actually make the throttle body open more? Does the little bit of extra opening actually give u any noticeable power gains?
Old May 11, 2019 | 05:46 PM
  #9682
Urbanengineer's Avatar
Bath time round 2, finally got all that maple syrup off my car.
Ugh so nice.
We don't live in common G areas lol.
Old May 11, 2019 | 05:48 PM
  #9683
G2B35AGN's Avatar
Good point. Perhaps that is my salvation.
Old May 11, 2019 | 09:02 PM
  #9684
LoSt180's Avatar
After a run around to hardware stores to find a missing cotter pin, calipers are built and ready to be installed. Ordered Akebono stickers. Glad I rebuilt them, found a torn boot and a few pistons didn't slide as easily as they should. OEM shims and springs are noticeably better quality than the ones that came with the pads, glad I picked those up.
Old May 11, 2019 | 10:18 PM
  #9685
I bought an obd2 chip today so i can see my throttle percentage when in arrives we will see. As for power gain it feels like it but it could be in my head
Old May 11, 2019 | 11:25 PM
  #9686
TattoosByCreech's Avatar
Bolt on. Tuned coupe
Rear end gears??
Recommend rear end gears for the G???
And more power???
ive done CAI, 75mm throttle body and spacer, 5/16 plenum spacer, Xpedal, Test pipes and full exhaust, Uprev tune. What should I do next?
Old May 11, 2019 | 11:36 PM
  #9687
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
5AT guys can benefit from the 3.5 gears out of a 6MT equipped differential. There is also a 3.7 geared diff from newer 370Z's that will work but that's damned steep in the 5AT and renders 1st gear sort of worthless in the 6MT unless you are on drag tires with a sequential transmission.
Tackle peripherial systems, brakes, suspension, cosmetic, etc. If you want more power adders you're limited to: 3.5" (or bigger) intake to take advantage of that 75mm TB, underdrive pulley, lightweight flywheel if 6MT, lightweight propeller shaft, cams, headers, lighter weight wheels, 2 piece lightweight rotors.
Also think about going forced induction.
Old May 12, 2019 | 07:55 AM
  #9688
Blue Dream's Avatar
I drove ttrank's car solo
I'm happy to see you mention this. Too many members just throw the bigger throttle body on expecting gains and it doesn't work that way.
Also OP, throttle body spacers do nothing on our cars. It's a often debated topic here but dyno testing has confirmed they are snake oil.
Old May 12, 2019 | 04:27 PM
  #9689
Drove it 5 hours to celebrate moms day.
Old May 12, 2019 | 05:50 PM
  #9690
Yinster's Avatar
5 Year Member
There was a small meet by miss HIN honolulu 2019, so i brought my car and my camera.... of course i grab a few pics !
