Crashed car due to camber kit. Pics
Old Nov 25, 2006 | 02:22 PM
  #121
phenom1011's Avatar
I had my kinetix kit installed by an alignment specific shop. They also put the control arms upside down (which has been corrected thanks to this thread starters original install pics.) The ball joint was still hitting the fender lining when going over bumps, but my alignment is within factory specs. I e-mailed kinetix and was told I was limited to how much positive camber i could have. Which means I need some neg. camber. I have the eibach pro kit which only lowers the car 1 inch. Whats the point of having this product if it can't correct the alignment and still have neg. camber?
If an alignment specific shop has trouble with no instructions of course you'll get bad installs and thus a bad rep. Also, why did kinetix allow their product to adjust to a point where it can be dangerous, especially if it don't come with instructions or a warning against such dangers?
Old Nov 27, 2006 | 09:42 AM
  #122
05Scoobyroo's Avatar
I still don't understand why they didn't send complete instructions. Even when I ordered my Plenum spacer, it came with complete detailed instructions, not a loosely applied "Guideline". I think if you produce a product, you should spell out to your customers "exactly" how to install it.
Old Sep 29, 2008 | 05:22 AM
  #123
ak808's Avatar
Really hate to bring an old thread up but, my rear kinetix camber/toe rod broke at the joint today while I was driving. Luckly I was going about 30ish and didn't crash. At first I thought I blew a tire but, found that my rear driver side tire was completely tilted. Looked under the car and found that the part where it connects to the frame just sheered right off. I didn't get a real good look at it since I haven't fixed it yet but from what I can see is that the circle/loop that the bolt goes into I assume is supposed to be completely round however, mines now looks like a U. Should there be anything else I should inspect or could have damaged besides that rod that I need to be worried about? Keep in mind that I'm not blaming anyone especially kinetix but, just check your camber parts (not sure how though) because this honestly could have been a lot worse.
Old Sep 30, 2008 | 08:50 AM
  #124
Maxypad's Avatar
just wondering but is that the candy red g35 bought for Hue Nguyen???
Old Sep 30, 2008 | 11:45 PM
  #125
G35JNKCV's Avatar
those are some bad *** rims
Old Oct 1, 2008 | 12:05 AM
  #126
lekker_droom's Avatar
old thread but still great info. Wonder if Kinetix has changed since '06?
Just go with 350evo or Stillen.
Old Oct 1, 2008 | 12:47 AM
  #127
jutn35's Avatar
G35 Coupe
can you obtain ur money back, or call for complaint ?
itschuckster
Jul 25, 2015 08:07 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
vstypicals
Jul 20, 2015 10:55 PM
Ninjay16
Jul 20, 2015 01:21 AM
Chattzx
Jul 17, 2015 11:23 AM
