Tiptronic help!!!
Old Feb 28, 2007 | 01:31 AM
STL_G's Avatar
Tiptronic help!!!
This has happened twice this week as well as a while back. When I go from drive to tiptronic mode, the instrument panel still shows the car in "D". Even if I shift up or down it still shows "D". Only when I restart the car does the problem goes away. I am over 70,xxx miles now! I hope this is not a problem starting to emerge. Any thoughts?
Old Feb 28, 2007 | 01:40 AM
StealthShinobi's Avatar
My Life be like Oooo ahhh
Are you still under warranty?
Old Feb 28, 2007 | 04:07 AM
jinubob81's Avatar
Evil Bastard
He is out of warranty unless he got an extended one that goes past 70k miles
OP: you can still shift in manu-matic mode, though? Even when the display shows "D"? Sounds like a wire got loose or went bad in the shifter hookup. there was a DIY here to reverse the shifting (pull to shift up instead of push) and that DIY page had pretty good info on what wire did what. It was either that DIY or a thread related to it. Try looking for that, and you might have a better idea on what to do. You could also try asking some of the wiring guys here.
Old Feb 28, 2007 | 04:43 PM
Fassster10's Avatar
you need to take it to the dealer and see what they say, it might be just electronic issue, i wouldnt take anywhere else since it sounds like something small, and if the mechanic has no idea what da hell they are doing then they might make something small into a big issue
Old Feb 28, 2007 | 04:53 PM
Jtrain's Avatar
Everytime I go into tiptronic it downshifts, sometimes owning my gearbox
i hate that!!
Old Feb 28, 2007 | 05:04 PM
michaeljr6's Avatar
shoulda gotten a manual
Old Feb 28, 2007 | 11:18 PM
DanejaPwnz's Avatar
i hope you guys arent changing from auto --to--> autoshift while moving the car. not that the car cant do it but it'd probably be better to do it while stopped.
Old Feb 28, 2007 | 11:20 PM
Canadian's Avatar
Canada, eh?
^^You kidding me?
Make sure you know what you're talking about before you post...
Old Feb 28, 2007 | 11:58 PM
xx7sephiroth7xx's Avatar
G
just a question, but when the car is moving and you switch from auto to manumatic, does the car shift down to 4th if you're in 5th @ the time?
Old Mar 1, 2007 | 12:04 AM
MikeButcher's Avatar
I think it does, i've noticed this before, but really haven't tested it out 100%...
I have noticed this before though.
Old Mar 1, 2007 | 12:56 AM
arjunz's Avatar
Originally Posted by Canadian
^^You kidding me?
You know, i've heard the whole.. switch it to MM mode when your stopped before as well, but i searched that topic and found nothing .. but its not the first time i've heard that.. ve heard a lot of people say that to me.. but never give me a legitimate reason.
Old Mar 1, 2007 | 01:16 AM
Strtsk8r321's Avatar
When you go to MM in 5th gear it always goes to 4th automatically!!
Old Mar 1, 2007 | 02:18 AM
STL_G's Avatar
No, I was parked and then switched to MM. I did not notice that it still showed "D" until I started shifting. I guess this is not a problem that has been heard of before. I did not get an extended warranty.
Old Mar 1, 2007 | 01:39 PM
I know I was answering someone else who was saying theirs switched to 4th from 5th. For your problem, I have never heard of something like that and you should have it checked out.
choosier
Nov 25, 2006 12:14 PM
Wizzathe1337
Feb 20, 2005 07:33 PM
G35Rush
Jun 29, 2004 03:19 PM
dennis_said
Jun 22, 2004 12:45 PM
RJP6
May 17, 2004 05:05 PM
