bogs out at about 6.5grand
Old May 31, 2004 | 09:57 PM
imRACERX's Avatar
so im working a new gto by a country mile but as i hit at or almost 6.5 grand somewhere around there just before shifting, it boged out from 2nd to third then again from 3rd to 4th. anyone else experience this? is this some kind of safety feature? please tell me it is. its not the head gaskets or anything like that cause it seems to be running fine. btw those new gto are slowwww. thanks
Clear markers w/ hid bulbs, Sprint springs, B&B Exhaust,JL Audio Hifonics combo.
Old May 31, 2004 | 10:07 PM
lorinserbenz's Avatar
Re: bogs out at about 6.5grand
You are hitting the rev limiter..
Old May 31, 2004 | 10:29 PM
imRACERX's Avatar
rev limiter? what the hell? my stangs never had that. anyone know what its set at and can it be changed? thanks X
Old May 31, 2004 | 10:32 PM
technosquare can raise your rev limiter to 7200 RPM for $595.
You would want to do this only after you have added other performance mods. They can change other settings to help increase performance as well.
Old Jun 1, 2004 | 01:11 AM
NismoV35's Avatar
From: Los Angeles, National Socialist Democratic Republic of Facistfornia
The Rev limiter is there to protect you from Valve Float. Helps you from damaging your engine..
GOT STICKERS?
CPV35 Driven BY David K, VQ35DEN Tuned By DR CHARLES
...........NismoCPV-35
Old Jun 1, 2004 | 02:10 AM
6mtInCharlotte's Avatar
I thought the new GTO had 350 hp?
Or is that a special model?
It's Austrailian by the way.
Old Jun 1, 2004 | 03:53 AM
metasystem's Avatar
04 G35 Coupe 6MT Gold Brembo’s
...sorry to go off topic from the rev limiter, but I agree with what was just said: the new GTO ain't no slouch -- it's got the (non-Z06) vette's 5.7L LS1 V8, good for 350hp. Even though the GTO with that big V8 is a couple of hundred pounds heavier than the G, you can't ignore that 70 hp advantage that raw displacement gives.
I think for stock cars with equal driver's the GTO should actually have the slight edge over our G (Pontiac claims 0-60 in 5.3s)
Mind you, that's in a straight line...
If we're talking cornering, lap times on a road course etc. then you're right, the lighter G should take the GTO with it's far superior handling, balance etc.
...and in a beauty contest... heh, well that's no contest ;-)
2004 G35C 6MT + Nav, Silverstone
Old Jun 1, 2004 | 07:15 AM
esemes's Avatar
its not THE REVVV LIMITER FELLAS......
when you are rowing between the gears, (1-2 and 2-3 respectively) you are actually breaking traction w/ the road (due to the snappy 6mt!!)... the "big brother" vdc senses this, and applies a breaking force---albeit brief and minimal-- which creates a bit of a bog...
it sucks, and even WITH VDC OFF, it STILL limits the performance..... i am trying to confirm this, and consequently find out how/where a disable is possible........ (no me gusta big brother)
until then, i am gonna use the VDC OFF module from our good friends at KP Technologies!!
-eS
**ps** the new gto is no joke (not including the style however) and has some serious grunt....(since itsa v8)
<P ID="edit"><FONT class="small"><EM>Edited by esemes on 06/01/04 04:18 AM.</EM></FONT></P>
Old Jun 1, 2004 | 08:20 AM
mamboking's Avatar
I just experienced what you just described this morning. Launching from a dead stop, as I was shifting from first to second, the engine lost its power. I also saw the SLIP light come on in the dashboard.
Old Jun 1, 2004 | 02:26 PM
I thought the rev limit was set at 6600? My car is a 5at and when using the manual mode I lose power right at 6600 with VDC off. The other night I hit it and it felt like my tranny smacked the bottom of the car.
Rhinos7777
Sep 6, 2015 05:36 PM
Geeed-UP
Mar 1, 2009 08:08 PM
NorCalGRide
Apr 5, 2007 07:21 AM
