Service Engine Soon Light-after Airbox
Old Aug 6, 2012 | 10:12 AM
jdb1's Avatar
I tried searching for the answer, but I still haven't found it. I just had my Infiniti dealer install the rev-up airbox to replace the POS CAI previously installed in my 2005 G35 Coupe. Now the Service engine soon light is on and will not go off. It has been 3 days since I had the airbox installed. Do I need to do the ECU reset by disconnecting the battery? Any help is appreciated.
Old Aug 6, 2012 | 10:53 AM
nism0350gts's Avatar
Yes. I would do an ECU reset by disconnecting the battery over night. I had this problem when i switched one intake setup over to another.
Old Aug 6, 2012 | 11:04 AM
jdb1's Avatar
When doing the battery disconnect, do I disconnect the entire battery or just the negative wire?
Old Aug 6, 2012 | 12:55 PM
lostangels01's Avatar
Negative wire should be fine, for about an hour. If that doesn't work look up ECU pedal reset procedure.
Old Aug 6, 2012 | 01:00 PM
gary c's Avatar
WRONG....^....disconnecting the battery over night the ECU will forget why it was ever installed in your car. An hour or so is the longest you should leave your battery disconnected! You had the dealership install the airbox and they didn't do it right so take it back to them. It's possible to clear the warning but if there's an issue it will continue to haunt you until corrected....Gary
Old Aug 6, 2012 | 04:53 PM
How so? Please explain Gary. I have done this numerous times with out any problems. What is your thought process on this? Yes i also agree if the dealership installed the airbox and you are now getting a SES light i would take it back to them.
Old Aug 6, 2012 | 05:38 PM
saywat?'s Avatar
lol at people disconnecting the battery to reset the ecu.
Old Aug 7, 2012 | 10:18 AM
gary c's Avatar
Like I posted, leaving your battery disconnected for a great length of time the ECU begins to forget simple things like idle rpms or advance. My friend Chris is a Nissan Master Tech and laughs at how many time a day he needs to reset customers ECUs because they left their battery disconnected over night. Installing spacers or intakes disconnecting is advised but only for an hour or so which will also clear most CES warning....Gary
Old Aug 14, 2012 | 05:13 PM
Was this issue resolved Jerry?
Old Aug 14, 2012 | 05:17 PM
dofu's Avatar
20 Year Member
Take it back to the dealer - they did the install.
And while it's common for the light to come on after some installs, I would not suggest resetting your ECU to clear it without checking what set it off first, just in case it actually is something more serious.
Old Aug 14, 2012 | 09:03 PM
jdb1's Avatar
It's at the dealer right now being checked. They put me a slow G37 sedan. I miss my 6MT already.
SiMpLyMoDiFiEd
The FX-Spot
Dec 2, 2021 04:35 PM
poker_lamina
Sep 1, 2015 09:04 AM
03sedang35
Aug 29, 2015 07:56 PM
linedr89
Aug 17, 2015 05:11 PM
igking
Jul 19, 2015 01:12 AM
