How much gains will i get with this?
Old Feb 1, 2015 | 09:56 PM
Siciliang35's Avatar
I'm new to the coupe , just got one ... Had a 02 maxima.
I been doing some research and from what I've read best hp mods are these
Spacers
Ztube
Xyz pipe
Is there anything I'm missing? My goal is to keep each mod at around 300, and i dont want forced induction or a loud exhaust
Old Feb 1, 2015 | 10:36 PM
Lartytiejdke3's Avatar
Not much-most will be from the plenum spacer. An exhaust with ART pipes and if you're a revup, an MREV2, plus a tune will be the difference maker
Keep searching around for first mod info. This entire site is damn near a "what should my first mods be" forum lol
Old Feb 1, 2015 | 10:49 PM
Urbanengineer's Avatar
All kinds of gainz!
Old Feb 1, 2015 | 10:58 PM
Its an 03
Old Feb 1, 2015 | 11:07 PM
gary c's Avatar
Read all the stickys at the top of the coupe page...knowledge is power!
Spacers Ztube Xyz pipe
According to Motordyne the spacer is worth 8 to 10 whp plus that much torque! The Z-Tube just changes the sound and offers zero gains! XYZ pipe is worth a few hp but it's the OE converters that cost you major hp. Replace them with HFCs (high flow cats) like Fast Intentions they're are worth 12+ hp! You can't just replace the converts and retain the OE exhaust, the increased flow will give you a terrible sound/rasp. Search using subject "Best Exhaust" that's where you'll find good advice on that subject. Good Luck and enjoy the ride...Gary
Old Feb 1, 2015 | 11:16 PM
I have been researching but i have some questions.
To Gary ... If i get a motordyne xyz pipe with hfc and stock exhaust i will get a raspy sound?
To anyone... Are my choices xyz pipe with straight pipe.... Xyz with hfc .... Or art pipe???? Or is the art pipe and xyz a diffrent part of the exhaust?
Old Feb 2, 2015 | 01:54 AM
I have been researching but i have some questions. To Gary ... If i get a motordyne xyz pipe with hfc and stock exhaust i will get a raspy sound? To anyone... Are my choices xyz pipe with straight pipe.... Xyz with hfc .... Or art pipe???? Or is the art pipe and xyz a diffrent part of the exhaust?
yes it will be raspy...
Art pipes and XYZ are different
Gary you get the next one lol
Old Feb 2, 2015 | 02:38 AM
Sorry for the stupid questions guys.. So the art pipe deletes the cat?
Old Feb 2, 2015 | 03:22 AM
yes. Or cats if you drive a g35 lol
Old Feb 2, 2015 | 03:33 AM
I'm in jersey too... No cats will i be able to pass inspection if i know someone? Or does the car have to get hooked up to the comp with no way around it?
Old Feb 2, 2015 | 06:31 AM
.cakestar's Avatar
vroooooooom
Old Feb 2, 2015 | 09:59 AM
art pipes most likely won't pass. But then again I can see our state failing people for hfc's as well too
Old Feb 3, 2015 | 10:27 AM
gary c's Avatar
Your OE exhaust system was only designed to hold so much volume, HFCs alone would give you rasp! It's like putting 3 lbs of dog **** in a 1 lb can, how's that for a visual?
Motordynes ART pipe replaces the converters, I ran these for a whole week and went back to HFCs!
Gary
Old Feb 3, 2015 | 11:07 AM
Hogbone's Avatar
Gary
Must likly due the smell OP, if your wondering why.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
magnetism80
Jan 27, 2016 12:57 PM
Usman Ali
Oct 4, 2015 08:23 PM
thechitoguy
Oct 1, 2015 05:25 PM
SePa_8310
Sep 16, 2015 04:32 AM
