Jdm transmission
Old Oct 5, 2018 | 02:12 PM
06mazdaspeed_6's Avatar
05 g35 2.5 inch exhaust
Jdm transmission
Hello I'm new to forum my girlfriends g35 is having transmission problems it's staying stuck in 4th. My question is does any one know if the jdm transmission is a direct fit on the U.S g35? I've searched for info but can't find any info about it.
Old Oct 5, 2018 | 02:38 PM
cswlightning's Avatar
That's what they sell em for!
Old Oct 5, 2018 | 02:42 PM
Do you know what years have the same transmission as a 05? Is it 03-07 g35s?
Old Oct 10, 2018 | 08:14 PM
frige's Avatar
Check with LKQ I have bought a lot from them and they know what will fit.
Old Oct 11, 2018 | 09:19 AM
Just order one from jdmnewyorki they helped me get the right transmission. So theres 2 different transmissions from what I was told they look exactly the same only difference is one has 3 green plug coming out the transmission from the valve body and the other only has one black plug that comes from the valve body.i have the transmission with only one black plug.
Old Oct 11, 2018 | 09:21 AM
thanks man ill keep them in mind just in case I ever need any other parts.
Old Oct 11, 2018 | 09:25 AM
These are the different plugs
Old Oct 11, 2018 | 12:08 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
That's correct, the green harness one has the TCM mounted next to the ECU inside the car, the black plug has the TCM inside the transmission behind the valve body. Tech ically they're ALL interchangeable with each other because you can swap the valve bodies and wiring harnesses. There were numerous smaller revisions for the black harness transmission but they'll all work.
MrPotatoeHead
Nov 17, 2006 01:16 PM
bileman
Interior
Oct 30, 2003 03:32 PM
