Horn Honks and cruise control blinks set when turning wheel
Old Nov 1, 2019 | 08:44 PM
Jasonpowell98's Avatar
G35 coupe
My horn didn’t work for awhile besides when I set my car alarm. then one day I noticed my cruise control would turn on when i turned the wheel the turned off when it was turned again. On another day I turned my wheel sharp to do a u turn and my horn would not turn off till I have turned the steering wheel again. Also horn goes off after setting the almarm. I have pulled the fuse for the horn but I’m just wondering what can be causing these problems.
Old Nov 1, 2019 | 11:36 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
I'm guessing a broken clock spring but you need to troubleshoot.
Old Nov 2, 2019 | 10:39 AM
G35 coupe
I was wanting to know how to trouble shoot I before I start taking my steering wheel apart
Old Nov 2, 2019 | 01:11 PM
cleric670's Avatar
BANNED!!!
https://www.nicoclub.com/archives/in...e-manuals.html
Section WW - Wiper, Washer, Horn. Also section ACS - Auto Cruise Control System.
Old Nov 3, 2019 | 10:35 AM
G35 coupe
Okay thanks just gives me some diagrams I suck ag reading can anything help me diagnose it?
Old Nov 3, 2019 | 01:41 PM
cleric670's Avatar
BANNED!!!
I suggest taking the vehicle to Nissan for a diagnostic if you're unable to follow the steps in the FSM. Otherwise you're going to end up throwing parts at the car which may or may not fix the issue. It's fairly straightforward though you have pinouts for the harness on the spiral cable / clock spring and the pinouts on the harnesses that they go to located in section PG - Power and Grounding. You use a digital multimeter to test continuity of the entire circuit from harness to harness and turn the steering wheel while doing so to see if they break continuity. If you lose continuity on the circuit or if they short out other circuits which is what it sounds like is happening then you can remove the clock spring and test both ends of it to see if circuits are shorting out internally.
skddmorse
Mar 10, 2015 08:24 AM
rbunch4468
Nov 15, 2012 06:17 AM
driftsucky
May 24, 2012 07:42 AM
2one8
May 24, 2012 01:49 AM
ryanm8
Sep 27, 2011 02:04 PM
