Throttle body and idle issues
Old Dec 4, 2019 | 02:35 PM
thenewworldman's Avatar
G35 Coupe 6MT
I recently did some work on my car and removed the throttle body. I did the reset procedure, however, the car still won't idle right and the car smells funny. Do you disconnect the battery and drain the capacitors? How do I get my car to run right again?
PS
No O2 sensor issues, the car has less than 84K on it.
Old Dec 4, 2019 | 04:37 PM
eazdaskeez's Avatar
Bluetooth Odb adapter and the NDS app might be able to help. The app can reset the idle for you given the right circumstances. Just did mines a few days ago after a throttle body cleaning.
Old Dec 4, 2019 | 08:48 PM
G35 Coupe 6MT
Thank you.
Old Dec 5, 2019 | 11:58 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
You need to do the idle air recalibration, Section EC - Engine Controls, page 79 of the FSM
https://www.nicoclub.com/archives/g3...procedure.html
NDS2 is easier but you need to buy the app and have an Android phone with a OBD2 BT adaptor.
Old Dec 7, 2019 | 12:36 PM
G35 Coupe 6MT
Torque App ?
I have the Torque app, the paid version. Can I reset on there?
Old Dec 7, 2019 | 12:38 PM
herrschaft's Avatar
And yes, you are supposed to drain the power before disconnecting the TB.
Old Dec 7, 2019 | 01:05 PM
eazdaskeez's Avatar
No torque doesn't have that ability.
Old Dec 7, 2019 | 10:01 PM
cleric670's Avatar
BANNED!!!
Just do the pedal dance method, use a stopwatch because the seconds counts need to be exact.
Old Dec 23, 2019 | 04:24 PM
Shaccoj's Avatar
Infiniti g35 base from what I can tell
Idle air control cel
I have a 2003 g35. Just bought off a friend, had to replace 02 sensor for emissions. Had an idle air control cel, friend read somewhere that replacing throttle body would fix. No big deal took care of it but the cel keeps coming back for the same issue. Idle relearn went fine but cant get this cleared to pass emissions.
Old Dec 24, 2019 | 02:16 PM
herrschaft's Avatar
What was the actual code?
Old Dec 27, 2019 | 12:00 PM
G35 Coupe 6MT
I realized I cracked my upper intake manifold by over torquing it. I put some JB Weld on there and it sealed up nice.
snopro
Jan 6, 2013 12:24 AM
fatherof2
Intake & Exhaust
Dec 29, 2012 11:26 PM
eddystone
Canada
11
Apr 21, 2011 01:56 AM
kingrukus
Jun 19, 2008 08:17 PM
kingrukus
Jun 16, 2008 08:38 PM
