Shifting (RPM) POWER
Old May 21, 2005 | 11:38 AM
05GCOUPE6MT's Avatar
What RPM do you guy drive and shift at ( normal driving ). What if considered safe? What is considered not safe? (or closer to danger zone)
POWER!!! Where does the power band lie? ie; what is the rang to get the most power out of the G. (4-5k RPM) (5-6K RPM) (6-7k RPM) .
Thanks guys,
Old May 21, 2005 | 11:42 AM
arjunz's Avatar
Check out the Drivers Manual, it tells you what Rpm you should shift at for every gear, i'd say shifting between 3-4K is safe ... The Power Band Obviously lies right at redline, before hitting the Limiter. When you hit the Limiter you obv. lose some speed and power.
Old May 22, 2005 | 11:25 AM
Anyone else.
Old May 22, 2005 | 12:41 PM
C-Keith's Avatar
As far as daily driving I probably shift gears right before 3k RPM; I drive more conservative than other though (my factory rear tires lasted 37k miles).
Old May 22, 2005 | 12:58 PM
IS300TOG35's Avatar
► Matt ◄
I shift at 2500 during warm up... 3k when im thinking about something or my mind is somewhere else.. and 3500 to 4k when im in high spirits
Old May 22, 2005 | 01:04 PM
Gman2004's Avatar
it's a freaking car guys and a sports car at that. Taking it to the red line is not going to kill it.
Old May 22, 2005 | 01:23 PM
Dsskyline's Avatar
How do you like the wheels? Did you post up pics already?
Old May 22, 2005 | 01:25 PM
Msedanman's Avatar
O.F. Administrator
Power drops off pretty much after 6.5k, a shift at that rpm brings you back into the good part of the torque band.
Normal everyday, non spirited shifting is prolly good anywhere from 2 - 3k
C.
Old May 22, 2005 | 01:29 PM
Speedoholic's Avatar
G (enie) FUNK ERA
I'd say the most power for me is around 4.5-6K rpms. Like Gsedanman said, when you get closer to redline, the power drops - you can see that on any Dyno machine.
As far as safety goes, I'd think that as long as you are not hitting redline on a regular basis (i.e. every time you shift), you should be ok.
Old May 22, 2005 | 05:13 PM
escobar929's Avatar
for me normal driving 2.3k to 2.7k, if i wanna let rip a lil 3.5k to 4.5k. if i wanna drive it like i stole it, then 6.8k.
esotericrider
V36 General Tech Questions
Mar 4, 2019 07:53 PM
_evilMonkey_
2nd Gen (V36) Sedan
Nov 22, 2015 06:21 PM
zcherub
Sep 10, 2015 12:03 PM
esotericrider
Northern California
Sep 10, 2015 02:28 AM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
