Oh No, What's Wrong With My G?
Old Mar 13, 2006 | 02:50 PM
tspree15's Avatar
I have a 2005 6MT.
For some reason when I reach high speeds on the freeway (65mph +, but the exact # varies) my slip light comes on and the ABS light comes on. The car drives fine though. When I turn off the car and turn it back on the lights are gone.
Today I was driving in 6th gear and I hit 65mph and the slip light came on and I had no acceleration power for 2 seconds. The car actually thought the tires were slipping.
What is going on?
Any ideas?
Old Mar 13, 2006 | 03:32 PM
truplay8's Avatar
THE BATMOBILE
take it to the dealership
Old Mar 13, 2006 | 03:50 PM
codeflux's Avatar
1. check your brake fluid level.
2. check your tires for (uneven) wear and (low) pressure.
if both above are fine, take it to the dealer.
Old Mar 13, 2006 | 03:58 PM
luongdmd's Avatar
don't mess with it... take it in..... still under warr.... why bother.. this way you get a loaner to play with as well....
Old Mar 13, 2006 | 06:29 PM
Gpair's Avatar
x 2
Old Mar 13, 2006 | 07:17 PM
glennp_1999's Avatar
Two things
1. Check your brake pads....if it's low the fluid level will do down and trip the warning lights on the dash.
2. If your pads are ok then check the brake fluid level.
If that doesn't fix your problem then take the car in for repairs.
Old Mar 13, 2006 | 11:27 PM
tspree15's Avatar
Thanks for the advice. I'll do my best to take it in to the dealer. You would be amazed at how terrible the Miami Infiniti dealership is. I've called 5 times and left 4 voice messges and still no call back from the maintenance dept.
If only I was near Lokey Infiniti...
Old Mar 14, 2006 | 12:03 AM
alexchuang's Avatar
well... if it is worth the X hour drive take it to Lokey... lol... if they miami dealership isnt returning your calls... talk to the GM... that usually solves the problem... infiniti dealerships usually pamper you though... i dont get it... at least the ones out here in california do... i drive to mines thats about 20 mins away and they greet me with a smile and say hello mr chuang how can we help you today... then i pop in the massaging chair in front of the plasma TV and wait for my car... free popcorn too... still workin on the free sodas haha...
Old Mar 14, 2006 | 04:33 AM
jaslui119's Avatar
I had the same problem...its ur throttle body that is causing this... Dont exactly know how and why it cuz the slip light to turn on but after my dealership change my throttle body the problem is GONE!
Old Mar 14, 2006 | 11:30 AM
drunkin master's Avatar
drive safe and take it in the dealer.
Old Mar 14, 2006 | 01:29 PM
tspree15's Avatar
Ah, throttle body...thanks for the info.
Yeah, I'm really surprised at how bad my local dealership is. I think I will contact the GM...in the past when I've tried to set up appointments for oil changes I just scream at the phone for a few minuts, drink a beer, and head to my local Jiffy Lube.
renbutler's Avatar
When I had the same problem, my brake pads were low.
Dallsinghjr1
Sep 17, 2023 11:25 AM
jeffbdye
Jun 1, 2018 03:51 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Visionnn
Oct 3, 2015 05:16 AM
Learned Hand
Oct 1, 2015 09:02 AM
