Calling all "X's" with a lowered suspension!
Old Mar 15, 2012 | 06:26 PM
  #2281
MPG35fiend's Avatar
Originally Posted by BuzzLightYear
I installed my coilovers this passed weekend and the ride was too bouncy in the rear for my liking. Yesterday I finally took out the back seats and installed the extenders and started tweaking the dampening. For the rear I'm 1 click away from full hard and the rear still has bounce. The bounces are short firm bounces but they happen with almost any imperfection in the road which in NY is just about all the time. Any ideas or is this normal? I'm only lowered 26.5 fender to floor in the front and 27 in the rear.
what kind of coil overs are they? i got bc coils the bounce sounds just like how you explained it when damper is set at 1-4 to hard, so maybe its normal.. have you adjusted your spring rates? maybe it needs more time to settle in since its colder in NY?.. i let mine settle for 2 weeks half way soft before i went back to set my spring rates, get it realigned and stiffened my dampers....
Old Mar 15, 2012 | 07:14 PM
  #2282
BuzzLightYear's Avatar
Yea I have the BC's also. I ended up setting them 9 clicks from hard in the rear and the bounce isn't as bad now. I havent even messed with the front settings yet. I've only put maybe 100 miles on my coils. I guess its a combination of letting them settle and adjusting the dampness till you find a combination that you like.
Old Mar 15, 2012 | 08:18 PM
  #2283
2006g35xsilver's Avatar
Sounds like your heights are off-probably have to add to the shock height only because they are not dampening the springs enough.
You shouldn't get anything resembling bounce at that high a setting if the heights are matched correctly. That's the trouble with the rears being separate height adjustment for the springs and shocks-you may have to take some time tweaking them.
Old Mar 16, 2012 | 11:30 AM
  #2284
MJION's Avatar
Still looking for a solid review on the Megan AWD Coils? Anybody?
Wondering if there are any disadvantages to these vs. BC?
Are they as easy to adjust?
Old Mar 16, 2012 | 12:32 PM
  #2285
Bastone's Avatar
So I just ordered a set of Tein Sedan S-Techs for my '05 X. Can't wait to install them.
I'll be running my OEM 350Z Touring 18s for the summer on 235/45/18 rubber. I spoke to Blain (4DGS) last night, and he said I shouldn't need a fender roll to run those.
My question is, will I be able to run my winter setup without rubbing (either on the inside or the fender edge)?
My winter setup is a set of OEM Maxima 18's on 225/45/18 rubbers.
I'm pretty sure the offsets are different, but I could be wrong.
Sample pic of the wheels in question.
Old Mar 16, 2012 | 01:31 PM
  #2286
If your winter tires are thinner/with same sidewall ratio and the summers work fine it should all depend on the offset-although if mm start to come into play the tread depth on the winters could matter but I doubt it.
Old Mar 22, 2012 | 04:50 PM
  #2287
vpV36's Avatar
1- BC Coils BR Type
2- pretty much all the way lowered
3- alright, would like to soften the ride a bit
4- trying to install the extendors, does anyone have a good method of taking apart the back panel? instead of jacking the car back up?
5- newely installed on sunday =)
6- fine!
7- getting 19 x 8.5 forgestar cf5 silver finish on 245/40/19 yoko s drives
Does anyone know if there is a DIY to install extendors?? I've been searching around the forums, and I've only found DIYs for the coils so far...
Old Mar 22, 2012 | 05:46 PM
  #2288
MJION's Avatar
^^Very nice! AND Forgestars are awesome... Good choice..
Any X guys know a place in Chicago to get coils installed? Picked up Megan coils the other day but no means to install..... My dream is so close but yet so far............
Old Mar 22, 2012 | 06:26 PM
  #2289
Originally Posted by vpV36
1- BC Coils BR Type
6- fine!
Unfortunately, I think it's easiest to install the extenders at the same time as the COs themselves-on the V35 X (not sure if V36 is same) you can put the extenders on before sticking the shock through the wheel well (it tightens on with an allen key), and then you can guide the extender up through the back by sticking your hand through on the side/top of the rear seat where it meets the interior side trim. You don't have to take anything inside the car apart.
I can see it working if you want to go the other way putting the extender through the seat onto the already installed shock but it would probably be next to impossible to get the allen bolt tightened securely.
Old Mar 23, 2012 | 10:19 AM
  #2290
Bastone's Avatar
1- TEIN S-Tech for G35 Sedan
2- 2.5" Front & 2" Rear
3- Quite nice. Was expecting it be way worse.
4- None so far. (Knock on wood)
5- 200kms
6- So far so good
7- OEM 350Z Touring 18s (I think ET30) on 235/45/18 Yokohama AVID EnVigor
Old Mar 23, 2012 | 03:59 PM
  #2291
vpV36's Avatar
thanks! i will make sure to post more pictures once the 'look' is complete!
thanks! we were thinking this was the quickest way of installing the extendors, but we wanted to see if there were other options before we go forward with this one!
Old Mar 23, 2012 | 09:14 PM
  #2292
BrianUzi's Avatar
Tein h-tech for g35x
I just bought some g35 sedan H-tech Springs for my g35x based on some stuff I read here. I was planning on putting these on for the summer and switching them back in the winter. Does it make sense to swap the springs seasonally? Is there anything else I should take into consideration, like wheel alignment? I remember reading somewhere that since the H-tech is a mild drop that this should not be a problem.
Old Mar 24, 2012 | 09:14 AM
  #2293
Bastone's Avatar
Depending on how much snow you get in your area, you probably don't need to switch them out for winter. Considering how slight of a drop the H-techs give, you won't be very far off from stock height.
Anytime you do suspension work, you should be doing an alignment as well, just to keep everything in spec.
Hope this helps.
Old Mar 24, 2012 | 02:03 PM
  #2294
GXXXV X's Avatar
1- BC Coils BR Type
6- fine!
Does anyone know if there is a DIY to install extenders?? I've been searching around the forums, and I've only found DIYs for the coils so far...
its pretty simple to do the extenders if you install them at the same time as the coils...put them in as one peice, but basically:
1- remove rear seat bottom, pulling on the two white tabs under the middle part of each seat
2- unscrew the bottom part of the seat backs, you should now be able to slide them up and out, you will understand how they go back in when you see the back of them it just hooks on
3- you should now be able to see the sealed off part where the shock housing is... if you want to install without lifting up the car, you will need to drill probably about a 2" hole PERFECTLY in the center...(im not sure how safe this large hole would be due to the 2 built in bolts nearby it but you should be fine). BE VERY CAREFUL when drilling the hole not to let the drill go too deep once it cuts through or else it will harm your shock adjustment ****! i am not sure how much clearance you have between them so either be careful when you do it or just lift the car up and do it.
4- once you have the **** in sight you can now put the extender on and thanks to the large hole you just drilled you should be able to fit the allen wrench in and tighten that **** up
5- when i put my seats back in i left the side of the seats that the extenders are on i left unhooked to give the xtenda some clearance so you can turn it freely... youll understand when you see it
hope this helps a bit
Old Mar 29, 2012 | 12:28 AM
  #2295
JAYRIPPA420's Avatar
i am looking to drop the car. the car is my wifes....but i always drive when not at work? whats the most recomended i dont wanna go thru tires like crazy.
i hear htech? but do they mean coupe or sedan. ? also does anyone have pics of an htech drop on a sedan?
You have already rated this thread Rating: Thread Rating: 3 votes, 4.33 average.
