Calling all "X's" with a lowered suspension!
Old Jan 14, 2013 | 02:02 AM
  #2491
G35X_204's Avatar
@ ajw2495
i have the same ride ... i'm currently dropped on the Z/G combo and it looks fine to me (drop was 1.2F and 1.1R after it settled)
the draw back is the back is a bit bouncy meaning when you drive over bumps your *** will bounce when ur sitting in the back u wont noticed it but when someone is driving behind you they will plus if you go over large bumps on the road you will "feel" it in the front like your shocks are going to give out but IMO its prolly cuz i have 19" Rays and the tires have a 40 series sidewall so not alot of meat to cushin the blow
i didn't have any camber issue as the drop was mild if you have the money buy coilovers BC Racing, Megan, D2 Racing are coils that fit and work well with a 1st gen X but front and rear camber kits will be necessary b/c you will want to go MOAR LOW after :P
hope this helps
Old Jan 14, 2013 | 07:44 AM
  #2492
ajw2495's Avatar
If you had to guess, if I were to buy that all right now, how much would it cost about?
Originally Posted by G35X_204
EDIT: i have 19x8.5 drags all around
@ ajw2495
hope this helps
Old Jan 14, 2013 | 12:44 PM
  #2493
ajw2495's Avatar
i just looked up the prices and there really expensive for coilovers. im looking to stay under 400 if i can for springs. any more suggestions?
@ ajw2495
hope this helps
Old Jan 14, 2013 | 01:09 PM
  #2494
G35X_204's Avatar
i see...the problem with dropping an X is there is no aftermarket front shocks to use (except the one of a kind Koni) which causes the front to feel like you hit a big pot hole unless you run a smaller rim with a bigger sidewall
its been well documented in this thread where if you just swap springs the front shocks will go and ride harsh over bumps
if you want a mild drop that wont break the bank go with the Z/G combo but beware of the bumps
IMO save some money and buy coils thats what i'm doing ... did the combo to get rid of some of the height until i can properly sit her low
Old Jan 14, 2013 | 03:19 PM
  #2495
ajw2495's Avatar
can i see a few recent pictures of your car?
Old Jan 14, 2013 | 03:23 PM
  #2496
Gtz1stballer92's Avatar
I'm at -3.7 front camber, def need a front camber kit. For u slammed awd sedans what's your front camber???
Old Jan 15, 2013 | 09:01 AM
  #2497
G35X_204's Avatar
@ajw2495
PM me your email and i'll send some when I can ... hopefully the pics will give you an idea on what you wana do
oh i forgot to mention that those front koni shocks were custom made one of a kind in case you were looking for a set of konis for an X
Old Jan 15, 2013 | 06:54 PM
  #2498
ArkansasG35COUPE's Avatar
Running about a -2 on my fronts after the slam.. And as far as staying under 400 bucks, just the install and alignment will be close to that.. My H&R's were about 265 shipped.
Old Jan 16, 2013 | 12:35 AM
  #2499
ajw2495's Avatar
ok i pmd you email.
@ajw2495
Old Jan 17, 2013 | 09:55 AM
  #2500
ajw2495's Avatar
hey guys so I found someone on the marketplace who is selling a set of 4 of the revised springs. Would I be able to use for 350z springs instead of two g and two z?
Does anyone have any suggestions for me? I have a 2006 X Sedan. It looks like the monster truck and I want to lower it. I don't want to do camber and stance it out, but I want to lower it at least an inch. I went through a lot of these pages and a lot of them are cambered. I'm looking to buy them by February.
Old Jan 17, 2013 | 10:04 AM
  #2501
FlyingLumpia's Avatar
I typed in 350z revised springs in the search function for this thread and got this.
Originally Posted by EkixDrive
Does anyone know if 2007 350z springs would fit my 06 g35x??? And will it be a nice drop??? Need answer asap thanks! Or do they have to be revised springs??
Originally Posted by Bastone
2007 350Z springs will fit your 2006 G35x.
They are the revised springs already.
They'll give you around 0.8" drop
I honestly think they will give you more of a drop. But the revised spring are stiffer and could make the car bouncy without some stiffer struts. The best you can do is get revised rear shocks but nothing up front right now.
Old Jan 19, 2013 | 01:19 AM
  #2502
RA71325's Avatar
Sorry to ask this question i know its been covered many times but i havent been following the suspenion page for the X for a long time, last time i checked it was the BC coils, megan, d2 that were the only coilovers for our car, anything else new?
Old Jan 19, 2013 | 09:37 AM
  #2503
Ralph0064's Avatar
^ K-SPORT but...out of all the ones available for the "X" BC is the way to go
Old Jan 19, 2013 | 10:40 AM
  #2504
ajw2495's Avatar
Okay so I found a pair of revised springs for the rear and im buying them from The Fixed. I found the front 350Z struts and springs. I think I'm going to just get both of these things and call it a day.
So at the end, I will have the revised G springs in the back, and the revised 350z struts and springs in the front.
Sound good?
Old Jan 19, 2013 | 01:16 PM
  #2505
Mike04x's Avatar
Sound good?
If I'm not mistaken the 350z front struts won't fit, you'll have to use your stock struts with the z springs
You have already rated this thread Rating: Thread Rating: 3 votes, 4.33 average.
