Calling all "X's" with a lowered suspension!
Old Apr 20, 2007 | 08:47 AM
  #241
KrazyEd's Avatar
Originally Posted by 2infinitibeyond
Newbie here, if you have a G35X, you can't run 20" staggered wheels (245/35/20 in the front and 275/30/20 in the rear)??? You have to remove the AWD fuse? (There is only a 0.81" difference in circumference and 0.26" difference in diameter) Can anyone help with this because I was really looking forward to getting staggered 20" Sevas S-22 wheels on my X. I appreciate it.
Yes, if you want to run staggered on the X you are going to have to remove the fuse. Oh and your tires sizes are correct.
Old Apr 20, 2007 | 11:11 AM
  #242
2infinitibeyond's Avatar
Originally Posted by FlyingLumpia
I emailed the guy never heard back from him. As for the Sevas cant answer in that department but when mine come in next week and I get tires on them I will post what a non staggered will look like.
Thanks KrazyEd, sad to hear that but appreciate it!
FlyingLumpia, I will be very interested in knowing how non staggered wheels look on your car because I will probably have to do this also (maybe use a wheel spacer to kick out the rear wheel?)
Old Apr 20, 2007 | 11:40 AM
  #243
KrazyEd's Avatar
You will not need a space to kick out the rear. 20x8.5 in the rear with a +40 to +45 will be fine. You will not need a spacer and it will fit with no problems.
Old Apr 28, 2007 | 12:39 AM
  #244
FlyingLumpia's Avatar
Here non Staggered on my X
I think it needs to be lowered more or atleast the trim painted. What do you guys think. I am going to get the ut lip in the rear.
Old Apr 28, 2007 | 03:02 AM
  #245
G-Mony's Avatar
Originally Posted by KrazyEd
Even if you were abe to do springs and shocks, your camber would still be off. Depending on your drop you will need to get a camber kit. For instance if you go with Z springs you will need a camber kit unless you like the negative camber look.
Getting new rear shocks will help the bouncing in the rear. There is not option for the front as of now unless you wantt o spend 1800 on coilovers from VRT.
Even w/ VRT coilovers...the camber will still be off. I went back to stock cos of that and turns out their rear is not adjustable. So no point in having adjustable coilovers if only front can be adjusted and not rears.
Old Apr 28, 2007 | 01:14 PM
  #246
apintojr's Avatar
the email i've been waiting for months now finally presented it self. my shocks are done and ready to be shipped =) just in time for the summer. finally i get to find out of all this waiting was worth it.
oh yeah, forgot to mention the two front shocks +shipping was a totall of $1,013 =( yeah i know ouch!
Old Apr 28, 2007 | 02:04 PM
  #247
Wow about time they get those finished.
Old May 1, 2007 | 05:00 PM
  #248
deltriggerhappy's Avatar
Does anybody know the difference between the coupe and the roadster springs?
Old May 2, 2007 | 07:40 AM
  #249
jimmyc13's Avatar
Figure I'd help you out, since you're new here & probably aren't familiar w/ the structure of the forum. Check out the tech area under suspension or search in the future...but this should be what you need:
https://g35driver.com/forums/brakes-suspension/65190-g35-350z-aftermarket-coilover-springs-shocks-spec-s-w-updates.html
If you mean Z-roadster, then the difference is 1/2" drop......Z = 1 inch drop (for sedan) and coupe = 1/2" drop (for sedan). Hope that helps.
Old May 2, 2007 | 08:27 AM
  #250
jimmyc13's Avatar
Guess I'll contribute & show my z spring/coupe spring setup as well...finally got around to giving it a good washing after getting the drop & my summer wheels back on.
Old May 7, 2007 | 10:22 AM
  #251
boraturbo's Avatar
Coupe springs
Anyone use OEM G35 M6 Coupe springs? Whats the drop? ride quality still good?
Old May 7, 2007 | 12:29 PM
  #252
Neal376's Avatar
hey guys
I can confirm fitment of the SPC Front camber A Arms on an 05x!!
but I only did the drivers side. I will do the passanger side later this week.
Old May 7, 2007 | 05:17 PM
  #253
apintojr's Avatar
well, i finally have my shocks in my hands. now as soon as my brake rotors come in, i'm on my way to the shop. =)
Old May 7, 2007 | 08:22 PM
  #254
seddon's Avatar
This is how the X looks with staggered wheels
Attached Thumbnails Calling all "X's" with a lowered suspension!-img_0114.jpg   Calling all "X's" with a lowered suspension!-untitled6.jpg   Calling all "X's" with a lowered suspension!-dsc00424.jpg
Old May 8, 2007 | 12:41 AM
  #255
Looks good seddon. Hey apintojr cant wait until you get them on. Who would I need to contact to get mine done. I know Koni but need a name or email.
You have already rated this thread Rating: Thread Rating: 3 votes, 4.33 average.
