Difference was NIGHT and DAY!!!
Old Aug 18, 2006 | 12:16 AM
  #76
lawrence's Avatar
I have an 04 with 5AT
will check with consult II
before and after
using grams per second @ diferent rpm
if i can find this around here.
Old Aug 18, 2006 | 01:20 AM
  #77
Jeff92se's Avatar
Red Card Crew
You mean the two torx bit screws? I unscrewed those and unplugged the connector. But I couldn't pry the sensor out. I can do this w/ our RX300 easy. Anyone remove the maf sensor this way? I don't want to break this thing. If I can expose the sensor itself, I can just use a Q-tip and rubbing achohol.
Originally Posted by codeflux
well, ok, that took like 30 minutes, including a 10-minute test drive. now, i have the pop-charger, so i unscrewed the MAF thingie from both ends (without removing the MAF sensor itself) and sprayed it from both ends a few times.
Old Aug 18, 2006 | 01:26 AM
  #78
codeflux's Avatar
oh no no no i didn't remove the sensor, didn't unplug the harness. i only freed the whole housing itself - z-tube from one side, jwt pop-charger from the other side.
do not remove the sensor itself, and keep q-tips away from it, unless you want to buy yourself a new sensor.
Old Aug 18, 2006 | 01:53 AM
  #79
Jeff92se's Avatar
Red Card Crew
I used the Q-tip on the RX300 a few times w/ no problems. It actually cleared a code. Is there something with the G MAF sensors that make them that fragile?
Old Aug 18, 2006 | 02:56 AM
  #80
codeflux's Avatar
if you have to ask, you don't know. if you don't know - DON'T MESS WITH IT.
Old Aug 18, 2006 | 03:04 AM
  #81
Jeff92se's Avatar
Red Card Crew
Actually I know too much. Older maxima MAFs were bulletproof. Newer 2k+ maximas = eh
I assume the G mafs are fragile.
Old Aug 18, 2006 | 07:30 AM
  #82
cato's Avatar
SouthernComfort Moderator
Crap! I removed the tube containing the MAF sensor and sprayed the sensor real good with the cleaner. When I put it all back togeather and started the car, the SES light came on. I cleared it with the pedal method, but it comes on immediatly after computer reset. I'm screwed!!!!! Looks like I need a new MAF sensor.
Old Aug 18, 2006 | 08:28 AM
  #83
rupdog326's Avatar
Out of many - one people
I removed the MAF sensor by unscrewing it from the housing. I then sprayed the sh*t out of it using the CRC MAF cleaner. I then drove from the Bronx to Queens and then from Queens to Yonkers.
Verdict: I can't really tell any difference.
Old Aug 18, 2006 | 11:26 AM
  #84
Jeff92se's Avatar
Red Card Crew
You were able to pull it out of the MAF tube?
Old Aug 18, 2006 | 11:28 AM
  #85
cato's Avatar
Be very careful when messing with the MAF sesnor. I just got a quote from the Stealership for $553.61 to replace it. Dang! I sure hope I can get mine operational again.
Old Aug 18, 2006 | 11:30 AM
  #86
chobble19's Avatar
Thumbs up
DAAAANNNNNNNNNNNGGGGGGGG we needa write uP!
Old Aug 18, 2006 | 11:31 AM
  #87
Jeff92se's Avatar
Red Card Crew
Hmm odd. If you reset the cel, it shouldn't read a maf code until you drive it and the ecu see's a problem. Is the connector "connected" right?
Do you have an OBDII scanner to read the actual code?
Old Aug 18, 2006 | 11:34 AM
  #88
chobble19's Avatar
what'd ya DO to it!??
Old Aug 18, 2006 | 11:37 AM
  #89
cato's Avatar
I'm hoping it is something really simple, like the connector being not tight. I reset the computer several times last night, and every time I restarted the engine, the CEL came on immediatley. The first time I started the car, the MAF was unpluged. My BAD. So I wasn't surprised to see the CEL, but then I plugged it up and it stays on. Oh GOD, why me?
Old Aug 18, 2006 | 11:56 AM
  #90
trey.hutcheson's Avatar
I can't remember when, or whom, but a few months back a guy was selling oem MAF's here on driver for pretty cheap. Cheap in comparison to $500. Someting on the order of $200 IIRC.
