e-fan conversion - dyno results!
Guest
Posts: n/a
OK, so finally I did a dyno comparison of 03 G35sedan with the stock clutch-fan (mechanical cooling fan), and after, with the e-fan conversion (dual electric fans). The after dyno is dated 01-sep-2006.
I had no doubt - I could feel it - but here's the charts...
Those observant amongst you will notice some differences - don't just take max HP as forgone conclusion. The first chart was the best of 4 runs. The last chart showing with the e-fan had 3 runs. the difference between the first and last 2 was letting the car cool down. It was 98deg during the dyno, so heat was a killer.
I'm a bit confused here. The prior dyno only went to 6300rpms whereas the new ones go to 6900rpms. The gains appear to occur above 6300rpms, but unfortunately we don't have that data for the pre-fan mod. If you look closely at the new dynos and compare them to the old dyno, you'll see that all the dynos show HP dip downwards at around 6100rpms, but then at around 6400rpms or so, the power starts to go up again. From what I can tell, comparing the before and after dyno up to 6300rpms shows no real difference.
Thanks for doing to comparison, but the lack of data on the first dyno doesn't make it easy to make a definitive answer.
Also, how were they able to get 6900rpms? Do you have a TS ECU?
on
Originally Posted by G35_TX
Actually it does if you look between the lines.
So how does this prove the conversion works
Originally Posted by DaveB
How so? His pre-fan dyno went to 6300rpms. His post-fan dyno clearly went above 6300rpms. On all dynos, pre and post, the numbers are the same below 6300rpms. The power difference on the post-fan dynos occured above 6300rpms, but the pre-fan dynos don't go that high.
There goes Dave again shooting everyone down like he did on the org.
But he is right, these dyno's don't tell us anything for the exact reasons he stated.
My point is, I don’t come to this board to see anyone attacked without cause.
Originally Posted by Gsedan35
At what point in this discussion did he become some sort of horrible person that is viciously "shooting" anyone down? Pretty sad when someone obliviously has a chip on their shoulder or is steeped in jealously and lets that get in the way of good forum etiquette. And let's play devil's advocate, if I'm wrong his posts in this thread and you’re stooping to the same level, what does that make you and anyone with the same intentions?
Hahaha....I know Dave from back in our Maxima days. I like him and he generally knows his stuff. I guess you could call it an inside joke since he always got crap back on maxima.org. I have no issue with him or what he posted, I agree with him.
-Mike
on
