Tps Help
Old Mar 11, 2007 | 02:53 PM
GGRJR's Avatar
Tps Help
The way I read the owners mabnual, the TPS sensors only send a siganal when the pressure is below the set limit, and speed above 20 mph. Correct?
Is there a way to test the sensors, without lowering the pressure and running down the road? Just ran to work, car felt a little strange, on the way, came out to find the rt rear flat. Never saw the light come on. These are my "new" 350 Z track wheels. Is the Z and G system the same?
Old Mar 11, 2007 | 06:55 PM
Andy77's Avatar
The sensors are in the valve stem. Were they transferred to the new wheels? If not, I hope you still have the stems because they are pretty expensive. Good luck.
Old Mar 11, 2007 | 07:55 PM
ttrank's Avatar
Grocery getter
Did you keep your same sensors? If the new wheels came with different ones in them they need to be programmed to your car.
Old Mar 11, 2007 | 09:08 PM
GGRJR's Avatar
No the Z track wheels came with the original sensors still in them. I am taking the car in for service this week, so I'll see whats involved, still have to get new tires so I have a little time any way.
Old Mar 11, 2007 | 09:57 PM
ttrank's Avatar
Grocery getter
I bet that is the problem. You need to have the dealer program the sensors to your car. I'm not sure if they have to take them out or just do some kind of learning routine.
Old Mar 11, 2007 | 09:58 PM
GGRJR's Avatar
Ok. I will ask while I'm in getting it serviced.
Mr. Wonderful
Jun 16, 2006 02:42 PM
Sportcoupe35
Jun 7, 2006 12:54 PM
TheKnite
Feb 14, 2006 05:45 PM
gettaluvr
Sep 11, 2005 03:31 PM
neffster
Jun 1, 2005 02:24 PM
