Sedans are as fast as coupes. go and tune
Old Mar 19, 2009 | 03:11 PM
  #76
Jeff92se's Avatar
Red Card Crew
For reference though, the oem 17" Z wheel is about 24 lbs each. I can't find a weight spec for the G oem 17s though. But I think I'm ball park right about the my wheel/tire coming in about 45 lbs.
Old Mar 19, 2009 | 03:39 PM
  #77
dofu's Avatar
20 Year Member
Originally Posted by DaveB
Then there's two other major factors at play:
1) With larger rims, the mass of wheel/tire is further from the hub which makes it harder to accelerate and turn.
2) Wider rims/tires and sticky tires greatly increase drag and wind resistance. A 245/40/19 is over 1.5" wider in profile. That's a big increase in drag.
My aftermarket 18" combo weighs 1lb less overall than my OEM 17s. The width of the 18" combo is 1.2" wider than the 17s. Overall, when I swap rims, my MPGs drop a solid 1-2mpg. That means the car is using my fuel/power to overcome the drag.
Hmm... fixed! While the bigger wheels requires lower profile tires which will be better for response, your turning radius has increased too.
And IMO, while weight does matter, size matters just as much.
Everything with cars is about balance. If it's not balanced, then it's either a give or take like DaveB is talking about.
Old Mar 19, 2009 | 03:42 PM
  #78
Klubbheads's Avatar
i know OEM 19 rears (8.5) are 22 lb each and the fronts (8.0) are 20lb each.
Old Mar 19, 2009 | 04:21 PM
  #79
Jeff92se's Avatar
Red Card Crew
I get 1 lb lighter for both but eh.. close enough
Old Mar 19, 2009 | 08:05 PM
  #80
gEE805's Avatar
lol when I said a delay I ment, the car doesnt pick up as fast/acclerate as it did with the 17's.
DaveB hit what I was thinking/ment... Im sorry but I still think the 19's are gonna slow you down some. And I know (Less tire more rims) can equal a tire with (more rubber and air & less rim). lol.....
I wished I still had my stocks so I could Weight them for own prefrence.
Old Mar 19, 2009 | 10:44 PM
  #81
Lucky-G's Avatar
So while we're on this discussion. Do my 15lb volk CE28 (18") with Bridgestone RE01R's weigh in at less than stock?
Old Mar 20, 2009 | 10:12 AM
  #82
Jeff92se's Avatar
Red Card Crew
Look up the weight of the tires and add it up
Old Mar 21, 2009 | 12:15 AM
  #83
Jeff92se's Avatar
Red Card Crew
Originally Posted by Jeff92se
The T1R is pretty light for a 19" tire. (I'm not that all enthused about their performance but anyhoo).
The cast 17" 17" wheel is NOT heavy. At least the premium wheels aren't. Just because a wheel is cast, doesn't mean it's heavy. It's very, very difficult to make a 19" wheel match the weight of a 17" wheel. The rear forged 19s are about 21lbs each. A rear 19 with a Michelin pilot sport (light for it's size) 255-35-19 comes in at about 45 lbs.
If I remember right, my blizzak and oem 17 weighed in at about 45lbs or so. The blizzak is 25 lbs so that puts the oem 17 at about 20lbs. I'll weigh them again when I swap.
Now the oem 18s are pretty heavy (Z and coupe). About 6 lbs each heavier than the Z track forged 18. 19lbs vs 25 lbs
I just weighed my 215-55-17 blizzak and oem wheel. 45 lbs. And from my other calculations for the fronts (coupe 19 and tire at 43 lbs), that's about right. I lifted both and my 19" combo is lighter. And my rears felt slightly heavier at 47lbs.
Old Mar 21, 2009 | 12:33 AM
  #84
DaveB's Avatar
Just swapped my 17s for my 18s today. My OEM Sport 17s with new 215/55R17 Falkens weighed in at 44lbs. My 18" ASAs with slightly used 235/45 P-Zeros weighed 46lbs.
Old Mar 21, 2009 | 12:49 AM
  #85
Skaterbasist's Avatar
Retired SuperMod
Sedans are faster than Coupes?
Coupes are faster than Sedans?
OEM 19's are heavy?
My dyno made better numbers than yours?
Entertaining thread to say the least
Old Mar 21, 2009 | 12:54 AM
  #86
4drmadness's Avatar
yup all my threads keep people entertained
OEM 19's are heavy?
Old Mar 21, 2009 | 01:15 AM
  #87
bonkrokz's Avatar
i just wanted to know if the fuel systems are different then coupes beside drive train loss in a sedan and the 2 extra doors is there any difference ?
Old Mar 21, 2009 | 03:07 AM
  #88
RPL's Avatar
RPL
Why would sedans have greater drivetrain loss?
Old Mar 21, 2009 | 02:05 PM
  #89
Texan1's Avatar
Q50 Red Sport 400 RWD
Originally Posted by 350Zed
Did you know that 87% of all statistics are made up on the spot?
did you know that 86% of all people that make up stats on the spot are 94% more likely to have someone tell them to shut their pieholes
Old Mar 21, 2009 | 03:01 PM
  #90
bonkrokz's Avatar
longer driveshaft then coupe and z, i think the z and coupe have c/f driveshafts aswell where sedans do not ..plus overall its a longer distance from the motor to the rearend ..
