Random Little Question Thread
Oh another question I have that wash door pull setup
Should I
-Look for someone to trade with
-Just pop them off and paint em
Heard the aluminum ones scratch easy! PM me if you have any ideas or custom work!
Should I
^in that case: https://g35driver.com/forums/body-in...pictorial.html
(Mine are holding up great BTW)
He converted to an E fan.
QUICK QUESTION
has anyone found a cheaper solution that the Viper for an Remote start??
My issues
-Don't want to spend over $250 overall
-Rather install myself
-Don't want to lose a key!
-Need to maintain FOB functions "windows down"
PS I remember reading about one that offed a windows up function as well"
THANKS
My issues
THANKS
Since you want to install yourself you dont have to pay labor you should be under $250 pending cost or alarm. I would look at basic 2 way system. Viper 5301 they can be had for under $100.
ok so i have a few questions that ive been searching for
-Where can i buy 2005-2006 reverse lamps (i have the tails)
-Where can i buy a m45 shift **** for A/T and do they fit the 03-04 sedan (even the newer OEM ***** would be great)
-where can i but the Stock front license plate cover for an 03-04 sedan (OB is color)
-how do you get to the bulb in the trunk i wanna replace it with an LED and i cant figure out how to get to it. (cant find a DIY)
-also im keeping my stock brakes but what are good brake pads
-our cars come stock with 17,18 and 19 inch rims if i upgrade from 17's to 19 inch oem rays will my speedometer be off?
-does the 05-06 steering wheel fit the 03-04?
-Where can i buy 2005-2006 reverse lamps (i have the tails) - eBay
-Where can i buy a m45 shift **** for A/T and do they fit the 03-04 sedan (even the newer OEM ***** would be great) - Riverside Infiniti. You'll probably have to do some modding to get it to work
-where can i but the Stock front license plate cover for an 03-04 sedan (OB is color) - Search the marketplace, or PM anyone you see that's recently upgraded or is upgrading bumpers
-how do you get to the bulb in the trunk i wanna replace it with an LED and i cant figure out how to get to it. (cant find a DIY) - Sorry, IDK.
-also im keeping my stock brakes but what are good brake pads - Probably Hawk
-our cars come stock with 17,18 and 19 inch rims if i upgrade from 17's to 19 inch oem rays will my speedometer be off? - not if you keep the diameter of the tire the same. (More wheel, less tire)
-does the 05-06 steering wheel fit the 03-04? - Should.
The same bulb that's in the clear corners/License plate lights can be used
