Random Little Question Thread
Old May 22, 2011 | 05:24 PM
  #3946
CG4DR's Avatar
just take off the jet chip and get a total tune for all your mods and you'll be fine
Old May 22, 2011 | 05:38 PM
  #3947
Gotdirt100's Avatar
Question Programmer
"well i guess that would be my issue, when you get ur ecu chipped through jet, they re map your stock ecu.. Meaning you cant just take it off. If i did get my car tuned from a shop exactly what would they tune? My ecy once again? Or do they do other stuff a programmer wouldn't be able to do?
Old May 22, 2011 | 06:10 PM
  #3948
xxxxxxxxxx's Avatar
is the coupe n1 lip the same as the sedan one?
Old May 22, 2011 | 06:26 PM
  #3949
Blue Dream's Avatar
I drove ttrank's car solo
Pretty much and it's just as ugly. If you're asking will the coupe lip fit on the sedan the answer is no.
If you're looking for a front lip get the OEM replica from Ionic.
Old May 23, 2011 | 03:05 AM
  #3950
DrewLe's Avatar
The only problem is that multi-X has an 03-04 sedan so the OEM replica from Ionic won't fit on his car.
.....unless he gets the nismo front and modifies the replica to fit, which would deff look sick
Old May 23, 2011 | 03:16 AM
  #3951
xxxxxxxxxx's Avatar
ooh idk i was just asking since they look the same i thought it would fit.
and yeah the nismo with the ionic lip would look hard but i think ill break it lol, ill stick with my oem for now
Old May 23, 2011 | 06:36 AM
  #3952
VincenzG35's Avatar
about how much does HKS exhaust go for? for 2003-2004 g35 sedan and if you guys can post specs and what you guys think thatd be great
Old May 23, 2011 | 03:36 PM
  #3953
NFSP G35's Avatar
? = 2B || !2B
Originally Posted by OCG35
you should be a trend setter and do venetian blinds (retro like Karmann Ghia)... or even more hard-core; Plantation Shutters
Or Untra Hard-Core and mold the rear/side windows and doors solid with the body
Roman Blinds!!!
Old May 23, 2011 | 03:38 PM
  #3954
NFSP G35's Avatar
? = 2B || !2B
Pansy!
Old May 23, 2011 | 10:45 PM
  #3955
GOAT35's Avatar
Help plz
I don't know if anyone is a mechanic and I understand you can't always find a problem with just hearing but if anyone has an idea what this problem might be please reply or dm! Thanks guys. I think it might be a spun rod bearing ps you can see a glimps of my baby in the vid.
http://youtu.be/rhHVjUxxgbI
Last edited by GOAT35; May 23, 2011 at 10:47 PM. Reason: cant figure out how to embed from youtube sorry!
Old May 23, 2011 | 10:54 PM
  #3956
VincenzG35's Avatar
Any response to the HKS?
Old May 23, 2011 | 11:16 PM
  #3957
Abax84's Avatar
Usually $350-400-ish for the rear section, maybe more now since HKS USA is no mo
Old May 23, 2011 | 11:20 PM
  #3958
NFSP G35's Avatar
? = 2B || !2B
What is the normal range for coolant temp on these cars? (when it's hot out)
Old May 23, 2011 | 11:22 PM
  #3959
thescreensavers's Avatar
Mr.202?
You can still order parts. But yes it ranges from there around
Old May 23, 2011 | 11:27 PM
  #3960
Mr.202?
https://g35driver.com/forums/g35-sed...formation.html
https://g35driver.com/forums/engine-...onversion.html
I think that info is in there somewhere
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
