Random Little Question Thread
Old Feb 7, 2012 | 09:34 PM
  #5656
g35nit's Avatar
my ?
Hey, i recently installed some aftermarket projectors on my 04 coupe. i post the pics, check them out. my trouble is that i transferred my 6k hid bulbs i had in my stock headlights. theyre super bright and im lighting up freeway over passes lol i need to find a way to lower the height of the beam or are the projectors adjustable? or should i get lower wattage bulbs?
help thx
Old Feb 7, 2012 | 10:39 PM
  #5657
Songle6MT's Avatar
Originally Posted by Matzo Ball
besides a bent wheel, what could cause the steerwheel to shake at 40mph+? I do have a slight bend on the outer lip of one of my wheels, but they balance to 0.
Even if they are balanced to 0 they can still cause vibrations....
Old Feb 7, 2012 | 10:41 PM
  #5658
thescreensavers's Avatar
Mr.202?
Have you tried a high speed road force balance? I will never just do a normal balance again.
Old Feb 7, 2012 | 10:45 PM
  #5659
NFSP G35's Avatar
? = 2B || !2B
Has anyone plugged in an OBD2 scanner and watched the temperature reading to know what our cars normally run?
Old Feb 7, 2012 | 11:08 PM
  #5660
G35enthusiast's Avatar
Shocks
I have a g35 coupe with 20x8.5 lexani LX-7 rims and 245/35 tires. I just wanted to know if I wanted to change my shocks would there be any rubbing issues and what shocks would you recommend?
Thanks
Old Feb 7, 2012 | 11:14 PM
  #5661
Mr.202?
Yep whats up? Want me to log something for ya?
Old Feb 7, 2012 | 11:37 PM
  #5662
NFSP G35's Avatar
? = 2B || !2B
^Yeah, if you're driving your car tomorrow, or if you have already done this in the past and can comment... what is the average range of temperatures reported by the computer, once you're up to temp? Idling and on hwy if you can manage it.
Old Feb 7, 2012 | 11:39 PM
  #5663
TORETTO's Avatar
Thanks
Shocks as in just shocks? Or full coilover setup.
I doubt you would rub with 20x8.5. Pics of the car.
Old Feb 7, 2012 | 11:48 PM
  #5664
NFSP G35's Avatar
? = 2B || !2B
hmmmm.... I'm beginning to wonder
Originally Posted by bigc
what he said, except the fans kick on low at 208F and high at 212F
Originally Posted by Tollboothwilley
My fans definely turn on at 194*(low) and 203*(high)
checked via OBDII
Old Feb 8, 2012 | 12:23 AM
  #5665
Mr.202?
Sure np.
Old Feb 8, 2012 | 10:37 AM
  #5666
Just eibach sportline springs to lower it a little bit.
Old Feb 8, 2012 | 10:54 AM
  #5667
CG4DR's Avatar
help thx
what wattage bulbs are you using and it could be the projectors themselves. might not have the proper cut off for the light glare
Old Feb 8, 2012 | 11:55 AM
  #5668
NjMatteSedan's Avatar
^ or maybe is because he is probably using h1 hids for reflectors instead.of D2Rs for projectors?
Old Feb 8, 2012 | 12:53 PM
  #5669
g35nit's Avatar
I have 6k bulbs running the projectors. Is there a way to adjust the cut off point?
Old Feb 8, 2012 | 01:08 PM
  #5670
g35nit's Avatar
I have 6k d2rs running the main light which is the projectors. I noticed the high beam light is an h1 bulb.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
