Random Little Question Thread
Rating: Thread Rating: 7 votes, 5.00 average.
Old Apr 1, 2012 | 03:45 AM
  #6061
dominate's Avatar
Was reading a thread on here where people were making a joke out of those Rotas (as well as Varrstoens but not as bad) = /
Old Apr 1, 2012 | 03:46 AM
  #6062
TORETTO's Avatar
yeah, the rotas don't have a great reputation (LOL).
Old Apr 1, 2012 | 03:47 AM
  #6063
TORETTO's Avatar
you gotta start somewhere I guess.
That same evo sold those rota's and picked up CCW LM20s later on.
Old Apr 1, 2012 | 03:50 AM
  #6064
dominate's Avatar
True that...just hope the Varrstoens will hold up...and hopefully this doesn't happen but if the wheels crack because of their inferior quality and cause damage to my car...fml...guess I can take the chance I can't find any threads where that specific design cracked or broke...I don't want to be riding on stock 17s for a long time lol..
  #6065
TORETTO's Avatar
So i guess what i'm saying is don't get expensive wheels now if you can't afford it. And since you don't want to roll stock, then get whats in your budget.
Then later on, just upgrade.
Old Apr 1, 2012 | 03:54 AM
  #6066
TORETTO's Avatar
they should hold up no problem. usually they only crack if someone runs over a 1 foot deep pothole or kisses the sidewalk at a good speed.
normal driving shouldn't crack them. people stress out too much about that.
Old Apr 1, 2012 | 03:57 AM
  #6067
dominate's Avatar
Yeah...I live in Hawaii...if you've never been here, our roads are pretty bad. Guess I just have to drive extra slow
Old Apr 1, 2012 | 03:58 AM
  #6068
TORETTO's Avatar
roads here aren't that much better. avoid what you can. small potholes shouldn't do anything.
Old Apr 1, 2012 | 04:10 AM
  #6069
dominate's Avatar
19x9.5 +30 should fit without fender work, if it's dropped with camber arms correct? And I should get hub rings since the bore is 73.1?
Old Apr 1, 2012 | 04:11 AM
  #6070
TORETTO's Avatar
you dont NEED hubrings, but i recommend it.
as for fitment. I'd ask a fitment guru about it. I don't know about the sedans.
Old Apr 1, 2012 | 04:17 AM
  #6071
dominate's Avatar
Ah okay thanks for the input
Old Apr 1, 2012 | 09:41 PM
  #6072
Reedtc's Avatar
Well I have this annoying thump usually when I first start my car in the morning and back out of my driveway(Only when turning the wheel) I've did my research and people say its the compression rod/bushings and some say its the ABS self test.
I only have this when I first start my car( sometimes when I'm driving and turning at a very low speed ) thats it.
Also when I ride and go over a little bump it sounds as if something is loose underneath and is going to just fall right off but when I check there is nothing visibly loose....
Help :/
Old Apr 2, 2012 | 02:18 AM
  #6073
thescreensavers's Avatar
Mr.202?
^ Does it sound like this ?
Old Apr 2, 2012 | 06:41 AM
  #6074
Reedtc's Avatar
No, Its more of a thump/knock that sometimes gets very serious and you can hear it from a distance. ..I think its the compression rod bushings >_<
Old Apr 2, 2012 | 10:41 AM
  #6075
Trickstyle's Avatar
bushings... go with some energy ones
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
