Random Little Question Thread
Rating: Thread Rating: 7 votes, 5.00 average.
Old Mar 25, 2012 | 11:07 PM
  #6016
thescreensavers's Avatar
Mr.202?
Originally Posted by Reedtc
I'm coming up on my first oil change since I had the car.(MPG extremely low...like 14mpg) Any suggestions on which oil to use? & air filter?
5W-30 any brand, though I prefer castrol, for oil filter avoid fram, purolator makes cheaper filters which are around the same price as fram and are much better in quality
Engine Air Filter- I generally use Wix Paper Filters, or Napa Gold(Which is also Wix)
How many Miles on the G? How are you calculating your MPG? City Driving?
Try resetting your ECU and have it relearn, all you need to do is unplug the negative terminal on your battery wait 30min or so and plug it back, your odometer should go blank and you will loose your radio presets.
Old Mar 26, 2012 | 07:18 AM
  #6017
Reedtc's Avatar
If you don't mind could you provide links to the products?
& I hit 140K . And I used the navi thing to tell me my mpg which I know is incorrect. I Ran to E & put gas in there then drove like a grandma and still got bad mileage -___-..But I do sometimes let my brother drive & he is a speed-a-holic soo thats probably where its coming from.
Old Mar 26, 2012 | 10:18 AM
  #6018
mook1186's Avatar
Radio/Center console faceplate
I have a 2006 G35 and I was wondering if anyone had any tips on how to remove the brushed aluminum faceplate the goes over all of the controls on radio and center console? Mine is scratched up and I wanted to refinish it to make it look better.
Old Mar 26, 2012 | 03:04 PM
  #6019
ray1370's Avatar
Just do some Google or Yahoo search you'll find tons of info about oil products, or you can just drop by any Pep Boys or Autozone stores to see for yourself - IMO if you really care about your G you shouldn't mind spend some time to shop around. Or you might as well just send it in to any Infiniti or Nissan dealership around you to have them do the service and check for all other issues on your car and go from there. What you got here and from another thread you asked about maintaining G should contain enough information for you to start with.
Originally Posted by TurTLe*
oil and air filter will not make much difference. If your getting 14mpg, you might need to change the driver.
If your car was poorly maintained and you changed everything to help MPG, you might see +1 mpg after all said and done. Thats filters,oil, tire pressure, cleaning out the trunk and other stuff. But changing your driving style/pattern can net you better MPG.
^ whs, changing engine oil you use won't change your MPG from 14 to 20. Our engines are not that gas saving to start with.
Old Mar 26, 2012 | 03:11 PM
  #6020
calcul8's Avatar
I can haz potato?
sabertooth tiger
For the last few years I've solely been using 5W30 Amsoil Euro Spec synthetic blend per bythabay's recommendation. Hasn't done me wrong so far.
Old Mar 26, 2012 | 03:44 PM
  #6021
Mr.202?
Just use the part finders, on their sites. Try this method: fill up, reset trip computer. Next time your fill up divide your Miles by Gallons.
If you are at 140k, did you do your spark plugs yet? Are you driving a lot of city?
Old Mar 26, 2012 | 05:09 PM
  #6022
Reedtc's Avatar
Can you give me a link to the air filter I would use for my 04 g35x sedan?
I haven't changed my spark plugs yet. I need to check into that. I don't know if the old owner did either
Old Mar 28, 2012 | 09:38 PM
  #6023
Ramanl's Avatar
quick question...
Is the hr y-pipe from a v36 sedan the same as the hr-y from a Z??
I found one from a v36 sedan, and want to know if its the same weight and fit as the Z hr-y
gonna put it in a 03 sedan
Old Mar 28, 2012 | 10:45 PM
  #6024
Songle6MT's Avatar
Originally Posted by Ramanl
quick question...
Should be the same
Old Mar 28, 2012 | 11:05 PM
  #6025
Max626's Avatar
For thoese who have done the suede headliner how many yards is needed to cover the headliner and A/B/C pillars along with sun visors.
Old Mar 29, 2012 | 01:10 AM
  #6026
Mr.202?
Originally Posted by Songle6MT
Should be the same
Its the same shape but at the end of this version it has resonators.
Old Mar 29, 2012 | 06:57 AM
  #6027
TurTLe*'s Avatar
air filter is about $10 if you go to pepboys. They are the same filter for my 98 maxima. You go in and there is a booklet in the filter section to look up what you need.
spark plugs were due at 105k i think. Pull one of the plugs off and judge from that. Most likely unless it was dealer service up to the point you owned it, its still original plugs.
You navi screen MPG is a little off. I manually calculated mines and it was LOWER then MPG screen. Its obviously to see why they would want to error to go OVER then under actual MPG. All cars are off by a little bit, but it does give you a good ballpark.
Old Mar 29, 2012 | 09:40 AM
  #6028
06G35Coupe94's Avatar
This might seem like a really stupid question but I need to know. I have an 06 auto Coupe that I bought a few months ago. How do i know if its the sport or base version. Im guessing base since its an auto but I want to know for sure. Again sorry if this was a stupid question...
Old Mar 29, 2012 | 09:46 AM
  #6029
TORETTO's Avatar
I believe sport adds spoiler, front bumper, skirts, springs.
Don't know if it was available on automatics, but I don't see why not.
Not a stupid question. At least you didn't go out and start a whole new thread about it. =)
Old Mar 29, 2012 | 10:06 AM
  #6030
mpugeda's Avatar
if you googled your own question you would have gotten the same result I did.
anyways, read this.............................................. .................................................. ......
https://g35driver.com/forums/buying-...t-package.html
Originally Posted by lelg35
The 05 sports sedan sports package does come with 18s. Anything less and it probably not the sports package. They are a split 5-spoke design with an Infiniti center cap. The 17's are a 7 spoke design. Also, the sports package brings a sports suspension. Make sure your shock absorbers are a red in color. Sorry, I don't have any pics right now to post.
Originally Posted by jawjaw
Wheels are the obvious clue but anyone can mount sport wheels on a non sport car. If you are actually able to see the vehicle, I believe the sport has different color shocks - red I believe.
Yes, the sport suspension brings red shocks and struts. Look for the red shocks/struts, 18 inch split 5 spoke wheels, and another clue, it better have the aluminum trim on the inside. The sport package can't be had with wood. I would say almost everyone has the alum. trim, but thought I'd mention that just in case. If you see wood, it surely didn't come from the factory with the sport package.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
