Random Little Question Thread
Rating: Thread Rating: 7 votes, 5.00 average.
Old Apr 20, 2012 | 07:53 PM
  #6166
NFSP G35's Avatar
? = 2B || !2B
^Ideally, spacers before alignment... and you're not going to get it in spec without an alignment.
Ask the alignment shop how much they'll charge to install the bolts for you, as there is some grinding involved (slot has to be lengthened)
Old Apr 20, 2012 | 08:55 PM
  #6167
Shanes_G's Avatar
i cant find the torque specs for the toe bolts, anyone know?
Old Apr 20, 2012 | 08:58 PM
  #6168
NFSP G35's Avatar
? = 2B || !2B
^A bazilliondy lb-ft
Old Apr 20, 2012 | 08:59 PM
  #6169
Shanes_G's Avatar
haha ill have the hulk torque them down then lol
Old Apr 20, 2012 | 09:17 PM
  #6170
TunerMax's Avatar
G35
Raising them will make it better, obviously. I don't htink those coils go back up to stock height so it'll never be 100% until you allign.
Stock Toe bolts might actually be fine for 2" of drop, but I'm not sure about that. And you have them, so may as well slap them in.
You need adjustable camber arms if you want to run proper camber, you know that right? Toe bolts are, clearly, only for toe.
And in theory (I think), spacers should make absolutely NO difference to your allignment
Old Apr 20, 2012 | 09:27 PM
  #6171
Shanes_G's Avatar
yea i know that, im not worryed about the camber. its not that bad. tow mixed with camber = goodbye tires. ive done lots of reading up on this. and thanks for your response, i will probably raise them up tm then.
Old Apr 21, 2012 | 01:03 AM
  #6172
TunerMax's Avatar
G35
Then perhaps you intended to write OEM TOE, instead of what you actually wrote.
(i will be running oem camber)
Old Apr 22, 2012 | 11:08 AM
  #6173
GreenPenguin's Avatar
Im hearing a noise from the rear end of my cabin when going over bumps/humps. The best way to describe it is if you put a stack of books or a five pound weight on the rear deck and as you hit a bump, the items are lifted into the air and then fall back down onto the deck. I checked my spare tire and it is tightly fastened down. Havent checked my scissor jack yet. Any idea's?
Old Apr 22, 2012 | 11:54 AM
  #6174
JAYRIPPA420's Avatar
endlinks may be bad
Old Apr 23, 2012 | 11:07 AM
  #6175
D.Reaper's Avatar
06 dual piston calipers compatible with 06 g35x?
Old Apr 23, 2012 | 11:18 AM
  #6176
NFSP G35's Avatar
? = 2B || !2B
Anyone ever put g37 seats in the first gen sedans?
Old Apr 23, 2012 | 01:23 PM
  #6177
thescreensavers's Avatar
Mr.202?
^ they arent plug and play, I dont think anyone has tried.
Old Apr 23, 2012 | 01:47 PM
  #6178
Blue Dream's Avatar
I drove ttrank's car solo
06X got the upgraded brakes finally so they're the same as the 06 2WD.
Old Apr 23, 2012 | 05:42 PM
  #6179
CG4DR's Avatar
Anyone using a Comptetion Clutch and flywheel combo?
Old Apr 23, 2012 | 11:30 PM
  #6180
06G35Coupe94's Avatar
After countless and countless failed search attempts ive decided to come and ask for help. I want to change almost if not all the vacuum, coolant, and radiator lines to the steel braided ones. I found out what sizes I need but I was wondering if there is a kit somewhere where I can buy the whole set? I dont want to individually buy the hoses and find out I bought the wrong ones, same with the fittings. Can someone help point me in the right direction? Thanks!!!!
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
