Random Little Question Thread
Old Jun 12, 2012 | 12:55 AM
  #6481
TunerMax's Avatar
G35
Originally Posted by Kingd
There is a red switch to the right of the hood latch and im not sure what it does, anyone care to help?
here it is
Uploaded with ImageShack.us
i dont know why its not showing the pic but it should show it if you click the icon
As eluded to, that's definately aftermarket. What it's for? Who knows. Something that's been removed or something you've never noticed. If you're really interested you'll have to hunt it down
Personally either way I'd remove it or change it to a switch that doesn't look so god aweful, man that's rough
Oh and get you some!
http://www.ebay.com/itm/Nissan-350Z-...bebc68&vxp=mtr
Old Jun 12, 2012 | 03:36 AM
  #6482
RADRaze2KX's Avatar
Is this a good deal?
http://compare.ebay.com/like/220895866330?var=lv&ltyp=AllFixedPriceItemTypes&var=sbar&_lwgsi=y&cbt=y
My headlights are getting to the point where I don't want to do a yearly restoration. There's too many leaks in the sealant and I'm too lazy to keep doing this every year hah. Thanks in advance.
Old Jun 12, 2012 | 04:42 AM
  #6483
dofu's Avatar
20 Year Member
Originally Posted by RADRaze2KX
http://compare.ebay.com/like/2208958..._lwgsi=y&cbt=y
They are a great deal if you don't want xenons. These things are halogens. You can always fix the leak in the sealant. A roll of the sealant from Nissan costs about $20.
http://www.mynismo.com/products/?id=5577
There are other stuff you can use as well, just look what people use when they do projector retrofits.
Old Jun 12, 2012 | 09:43 AM
  #6484
Kingd's Avatar
Damn this red switch is going to drive me crazy. My G is auto i dont know if that would work? haha ive been looking for a set but no luck, my pedals look so awful
Originally Posted by ME GUSTA
damn by hood latch i thought you meant the locking mechanism on the hood itself.
yeah by the hood latch
Old Jun 12, 2012 | 12:53 PM
  #6485
G35Papa's Avatar
^You can use the clutch pedal for your e-brake pedal
Old Jun 12, 2012 | 05:44 PM
  #6486
TunerMax's Avatar
G35
http://www.ebay.com/itm/ALUMINUM-PED...e29ec1&vxp=mtr
Old Jun 12, 2012 | 09:46 PM
  #6487
g35_white's Avatar
I got P1122. I did a brief search and it is something related to Throttle Body.
What should i do? I reset it for now. Should i also quick reset ECU? Also if i do a quick reset of ECU, is there a radio password that i should be aware of? I have a 05 g35 sedan.
can i clean throttle body? Will the problem get solved with that? Or do i just need to replace the TB?
Thank you
Old Jun 12, 2012 | 11:17 PM
  #6488
NFSP G35's Avatar
? = 2B || !2B
Throttle body relearn for starters
Old Jun 13, 2012 | 12:05 AM
  #6489
g35_white's Avatar
how to do that?
i came across these terms: Accelerator Pedal Released Position Learning , Throttle Valve Closed Position Learning and target idle speed. don't know how to do throttle body relearn. please advise.
my idle rpm is around 650-750 without ac and 1 tick before 1k rpm with ac.
thanks
Old Jun 13, 2012 | 12:15 AM
  #6490
NFSP G35's Avatar
? = 2B || !2B
I believe that's the one you want.
Old Jun 13, 2012 | 12:34 AM
  #6491
g35_white's Avatar
So i am going to follow the steps below
1. Make sure that accelerator pedal is fully released.
2. Turn ignition switch “ON”.
3. Turn ignition switch “OFF” wait at least 10 seconds.
Make sure that throttle valve moves during above 10 seconds by confirming the operating sound.
Now before doing this, should i disconnect the battery and reconnect after 15-20 mins or can i do it right away?
How to confirm that throttle valve moves? What kind of sound should i look for?
if i disconnect battery, do i lose radio password if any there? I don't want to be left radio-less and then go to dealership where they may try to rip me in name of password.
please advise. sorry for asking naive questions, i am trying something like this for first time in life so a little
Old Jun 13, 2012 | 05:11 PM
  #6492
DVG's Avatar
DVG
I want to reduce my wheel gap a bit (2003 sedan). My friend wants to sell me his 350Z H techs.
2 questions:
1. What will give me a better look - the H techs or the G/Z combo - wheel gap is whats important to me. I want it EVEN and reduced.
2. Will I need a camber kit for either set up?
Old Jun 13, 2012 | 07:03 PM
  #6493
NFSP G35's Avatar
? = 2B || !2B
G/Z won't eliminate fender gap. Htechs should, but you'll probably want a camber kit for them, just in case
Old Jun 13, 2012 | 08:02 PM
  #6494
VincenzG35's Avatar
Does anyone have the Links to the PDF repair manual I can't find them
Old Jun 13, 2012 | 08:03 PM
  #6495
TORETTO's Avatar
right here bro
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
