Random Little Question Thread
Old Jun 14, 2012 | 01:46 PM
  #6511
TunerMax's Avatar
G35
Originally Posted by DVG
Im getting used OEM suspension from a 350Z or a g/z combo, I am still trying to figure out exactly what Im looking for. (Unrevised/revised and all the combos possible)
Ive taken a quick look though, and it seems they are usually in the range of 80-120 for a set. So if I can get camber for all the wheels for like 300 or something that would be good. It may turn out that I only need it on one axle too.
Correct me if Im wrong - I only need a camber kit if I cant get the camber within spec as is, right? So I could just get springs, go get it alligned, and if they say they couldnt align the rear, I could just go get rear camber. Is that correct?
As I understand it, there's no camber adjustment on our cars at all from the factory, only Toe, hence the need for aftermarket camber arms.
And over 1-2" you'll need aftermarket toe bolts also because the stock ones have hardly any adjustment (rear). Those are cheap though.
Old Jun 14, 2012 | 01:49 PM
  #6512
TunerMax's Avatar
G35
Originally Posted by jeggo
This guy needs camber kit and toe bolts.
I went and looked at SPC, they costed like 900 for a front set and 130 each for the rear. Was I looking at the wrong thing? If I can get a camber kit for a reasonable pric Id be on board, but I have an absolute limit of $500 for suspension mods.
Dunno what you were looking at but IIRC around $400-700 for front AND rear with toe bolts.
$500 limit to drop your car? No sir, that won't happen unless you do it improperly. Save up more money.
Old Jun 14, 2012 | 01:57 PM
  #6513
LMAO's Avatar
My parking brake doesn't work on my 03 5AT sedan. I found a writeup on here, but it was for a 6MT with the handle. Mine is the foot brake. Also, none of the pictures loaded in that writeup. I found the part int he service manual about adjusting it, but I have no idea what it's talking about. Can someone point me in the right direction?
Old Jun 14, 2012 | 02:10 PM
  #6514
DVG's Avatar
DVG
If I can get front and rear with toe bolts for 400, I can do that. That is actually close to my spend cap because used oem springs are fairly cheap. Can anyone show me where I can get camber + toe bolts front/rear for around that price?
Old Jun 14, 2012 | 02:13 PM
  #6515
DVG's Avatar
DVG
I thought a lot of people ran 350z revised or G/Z combo without needing camber kit though.
I do need some new toe bolts
Old Jun 14, 2012 | 06:57 PM
  #6516
TunerMax's Avatar
G35
If the 350Z upper control arm is different like I'd suspect it is, you could try to get one of them with the 350Z spring for the front. pure speculation though, I have no idea if they're different.
Old Jun 14, 2012 | 07:24 PM
  #6517
jdubin94's Avatar
Dual climate wont work?
Ok. Just swapped my display unit and now my dual clumate wont work? All the wires on the wiring harness seemed to be fine. What could the issue be?
P.S. I tried searching first
Old Jun 14, 2012 | 07:51 PM
  #6518
Trickstyle's Avatar
Originally Posted by jdubin94
Ok. Just swapped my disay unit and now my dual clumate wont work? All the wires on the wiring harness seemed to be fine. What could the issue be?
disay?
if only your DCC went out I'm guessing its most likely a problem with the AC board itself, if you have an OEM stereo then gear up for a boatload of other stereo/AC problems until the thing just flat out dies... may i suggest you turn your temp to 75 and put the fan speed on the second notch. when it dies your ac settings will be locked in place. mine was blasting 90 constantly as for a solution? if you're rockin OEM, go with a double din(not metra) setup. if you're already rockin a double din, try out a new AC board. and btw, when it comes to circuit boards, try not to touch the semiconductors(resistors, transistors, ICs etc.), the grease from your fingers will get on them and as they are working(and giving off heat) the grease will heat up and can fry the component. that could be what happened to you idk.
Old Jun 14, 2012 | 08:09 PM
  #6519
jdubin94's Avatar
Does anyone know if some 05-07 gs come without dual climate?
Old Jun 14, 2012 | 10:19 PM
  #6520
NFSP G35's Avatar
? = 2B || !2B
If anyone has a set of stock control arms off of their sedan, please let me know so we can measure them.
My cousin has his stock ones off his 350Z so we can compare and see if that's an option (would be a really sweet option, considering stock 350Z suspension parts should be pretty readily available)
Old Jun 14, 2012 | 10:26 PM
  #6521
DrivenG's Avatar
Mine are sitting in my Garage. Want to buy them lol. I can measure them if u want.
Old Jun 14, 2012 | 10:31 PM
  #6522
DVG's Avatar
DVG
I was trying to upload a picture of what I found under passenger kick plate, but the upload is failing. Can anyone point me to a comparison of 2003.5 / 2003.0 ECUs so I can tell which one I have?
Old Jun 14, 2012 | 10:42 PM
  #6523
NFSP G35's Avatar
? = 2B || !2B
^If you unplug it (you have to flip the arm/latch to get it to come off) look at the connectors on the ECU itself. If they are black, it's new... gray is old.
Old Jun 14, 2012 | 10:46 PM
  #6524
SooWoo's Avatar
anyone know where im able to get the undercarrige splash cover/ ender engine cover that covers the aleternator ? other than a dealer? for a 2003 sedan
i also want the 05/06 tail lights
Old Jun 14, 2012 | 10:53 PM
  #6525
DVG's Avatar
DVG
I unhooked a black latch and pulled it across, that slightly lowered what I think is the ECU and it is gray. Am I SOL?
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
