Random Little Question Thread
Old Sep 29, 2012 | 02:06 PM
  #7321
3pedalsdn's Avatar
Is there a diy for removing the window trim? Also where can I get the replacements if mine happen to bend?? TIA.
Old Sep 30, 2012 | 11:55 AM
  #7322
DVG's Avatar
DVG
I can get the 2 front akebono calipers for $330. Good deal? (Used) Appearance isnt an issue because Im going to get them powdercoated. Is mileage an issue with something like calipers? Should I get a rebuild kit for it?
Old Sep 30, 2012 | 01:32 PM
  #7323
TunerMax's Avatar
G35
Just the calipers? not a good deal. you will need pads rotors calipers and adapter brackets which will cost an arm and leg.
The entire kit is around $1800 for everything, front and rear.
Old Sep 30, 2012 | 05:13 PM
  #7324
TurTLe*'s Avatar
in terms of rebuilt, its nothing more then a couple of piston seals. I wouldn't bother unless you notice a torn seal.
Old Oct 1, 2012 | 01:26 AM
  #7325
Carmelo's Avatar
Unhappy Do I have HIDS?
So I have a 2003 G sedan and I just noticed when I turn my lights on, the top ones don't work. The bottom lights work they're a white-ish amber color so I know they're not HIDs.
The top lights both have bulbs in them but they don't turn on, even when I turn my high beams on, they come on at the bottom!
Is that normal? How can I tell if I have HIDs?
Please help!!!!!!
Old Oct 1, 2012 | 02:17 AM
  #7326
JOKER's Avatar
CLUB MODERATOR
if your top light don't work, your question should be "Why they don't work?" not "Are they HID'S"
Pull the bulbs out and you'll be able to tell if they are HIDs or not.
If I remember correctly in 03 they were not HIDs .
Old Oct 1, 2012 | 04:39 AM
  #7327
Blue Dream's Avatar
I drove ttrank's car solo
03 sedans have halogen headlights, but Joker's right. If your top bulbs don't turn on that's a problem.
Old Oct 1, 2012 | 07:09 AM
  #7328
DVG's Avatar
DVG
Well I also wanted to get 2 piece rotors which I think adds about $600 to the price, bringing it to 2440. I can get the full set of rotors, pads, lines and fluid for 1092, and the adapters for 195. Only thing I would be missing is shims which I am assuming would be cheap. 2440-(1092+195) = 1153. Which means I would have that much to spend on calipers + shims to come out even.
Am I missing something?
Old Oct 1, 2012 | 11:37 AM
  #7329
bnails's Avatar
Mite be an obvious question, but did you check to make sure that the switch is on for those second lights? Cause arent they the fog lights or something like that?
Old Oct 1, 2012 | 11:54 AM
  #7330
NFSP G35's Avatar
? = 2B || !2B
FYI, it is possible to get a 2003.5 With HIDs
Old Oct 1, 2012 | 12:27 PM
  #7331
TunerMax's Avatar
G35
This^^ It was an option in 03
Old Oct 1, 2012 | 02:25 PM
  #7332
DVG's Avatar
DVG
Though I could always spring for this BBK, at a steal of$45
http://www.ebay.ca/itm/Brembo-Calipe...item2a097c042e
Old Oct 1, 2012 | 02:26 PM
  #7333
DVG's Avatar
DVG
Also, I have a 2003.0 sedan and it came with HIDs
Old Oct 1, 2012 | 02:48 PM
  #7334
MPG35fiend's Avatar
is that a reall bbk? looks like its just a caliper cover....
Old Oct 1, 2012 | 03:53 PM
  #7335
DVG's Avatar
DVG
It was a joke lol
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
