Random Little Question Thread
Old Dec 19, 2012 | 10:30 PM
  #7951
dominate's Avatar
Originally Posted by TunerMax
IMO, that doesn't look like previous body work, that sounds like a crappy excuse the shop that rolled used.
That looks like getting too aggressive with the roller (trying to go way too fast) without warming the paint to allow it to stretch.
But I'm VERY far from experienced/expert with this. How does the inner poriton of the fender look, does it look like it had bondo work?
To be fair to the shop, they build great show VIP cars, and warned me that if the car had previous body work, then it could crack. The inner fender is fine, but the area by the gas door has scratches under the paint, which the shop told me is probably body work.
Old Dec 19, 2012 | 10:34 PM
  #7952
NFSP G35's Avatar
? = 2B || !2B
Some paint is more brittle, and also heat is a must.
Old Dec 19, 2012 | 10:35 PM
  #7953
dominate's Avatar
Yeah oh well....so like ME GUSTA said, I should get some paint sealant for it? Maybe have a body shop do it?
Old Dec 20, 2012 | 09:53 PM
  #7954
dominate's Avatar
And I'm also ordering the ionic nismo lip tonight, debating whether or not to order it painted...its only $120 extra for paint but my car would be in the shop anyway for a paint and install of a front lip..car color is BO
Old Dec 21, 2012 | 02:19 AM
  #7955
G35AndTGOD's Avatar
Coupe an sedan Caliper fitment
I'm selling my brembo brakes and someone offered me stock 05 sedan calipers will those fit my 04 coupe?
-thanks
Old Dec 21, 2012 | 02:58 AM
  #7956
SDGenius's Avatar
yes
Old Dec 23, 2012 | 02:41 PM
  #7957
NeverTooFast's Avatar
Unhappy 1/2 motorydyne iso thermal plenum spacer
This is my first post so bare with me, I have an automatic 2005 g35x and I have searched everywhere but apparently I'm the only one who found a problem, when I try and buy one in the description it says hood will need to be modified in order for it to fit correctly is this true or will it fit proper? I dont want to buy it then find out I need to buy a whole different hood for my car, I'm alright if it barely touches the hood. Also, I'm only 17 and my car knowledge isn't exactly the highest, would I be able to install it myself? Would it be better to do myself or just save the trouble and bring It to a mechanic?
Old Dec 23, 2012 | 02:47 PM
  #7958
herrschaft's Avatar
Unless the engine in an X sets higher then in the coupe there should not be any issues with the hood, I'd wait for others to verify though. As for installation, it isn't difficult at all just remember to put everything back where it came from. Be sure to disconnect the battery before touching the throttle body and don't over torque any bolts. There's DIY's on youtube regarding installation and shouldn't take more then an hour.
Old Dec 23, 2012 | 03:31 PM
  #7959
http://www.ebay.com/itm/MOTORDYNE-1-...f84775&vxp=mtr
This is the one I will be buying in case I misread, or if anyone wants to recommend something better. Thank you for the feedback
Old Dec 23, 2012 | 04:22 PM
  #7960
short it's Avatar
has anyone removed the air intake
Hi folks.
There's a black plastic cowling that ducts air into the air filter box. On my car, it was rattling because the plastic fasteners were old. I removed the item. Has anyone done this / left it off?
What's the expected result?
regards
Old Dec 23, 2012 | 04:40 PM
  #7961
TunerMax's Avatar
G35
You just mis-read dude.
The only thing that needs to be modified with the 1/2" Spacer is the engine cover, because the threads that hold it are not long enough once you install the spacer.
You can choose to simply leave the plastic cover off, or you can get a 5/16" spacer.
Old Dec 24, 2012 | 02:45 AM
  #7962
SkinnyD35X's Avatar
Very useful thread.
Old Dec 24, 2012 | 08:37 AM
  #7963
TunerMax's Avatar
G35
Originally Posted by short it
Hi folks.
regards
search "Infiniti Nissan Clips" in ebay or where ever and you will find 25-50 packs for under $15
Or just go to Nissan/Infiniti and buy some, more expensive though.
There's no reason to leave it off, really. It won't HURT anything to leave it off, but it does decrease the efficancy of the intake.
Old Dec 25, 2012 | 11:53 PM
  #7964
Airic214's Avatar
hey does anyone know if this exhaust is good? it seems pretty cheap
http://www.ebay.com/itm/Infiniti-G35...90458674172%26
Old Dec 26, 2012 | 12:01 AM
  #7965
rnguyen's Avatar
Sup guys I was just wondering has anyone painted their brake calipers and if so how did they come out
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
