Random Little Question Thread
Rating: Thread Rating: 7 votes, 5.00 average.
Old Apr 4, 2013 | 04:36 PM
  #8866
spades_03's Avatar
Originally Posted by TORETTO
In other news, any trick to getting out an o2 sensor? (for my beater)
I can't exactly fit my socket over the damn thing, thanks to the wire. Crescent wrench is a no go, the head of the o2 sensor is in a hole, where only a socket would reach into.
there is a tool for it
o2 sensor socket
http://www.harborfreight.com/3-8-eig...nch-97177.html
Old Apr 4, 2013 | 05:32 PM
  #8867
TORETTO's Avatar
just bought one from autozone. had to dig up an old 3/8 ratchet to use it.
Old Apr 4, 2013 | 05:34 PM
  #8868
That G Gray's Avatar
Old Apr 4, 2013 | 06:50 PM
  #8869
TunerMax's Avatar
G35
if it's still tight use some PB blaster and let it soak for a few couple.
You can also tap around the 'bung' where the O2 sensor threads into to shock it free.
The G mostly a car show baby then?
Old Apr 4, 2013 | 07:05 PM
  #8870
TORETTO's Avatar
finished changing the O2, just placed a cheater bar over the small ratchet and spun it right off.
I don't even go to shows with the G35 lol.
Old Apr 4, 2013 | 07:32 PM
  #8871
HereKittyKitty's Avatar
Originally Posted by dofu
Driving a slammed ride is a form of art, gotta keep weaving around all the bumps and potholes. Or you can just drive it like you stole it and deal with the broken parts later.
I'm willing to bet hitting the bump jolted a battery terminal, turning on the SES light. Happened to my G all the time. Every now and then the negative terminal even pops off, stalling the car. That happened until I decided to put a wood screw through the terminal to make sure it holds.
If you are having problems driving over those bumps at even 45MPH, then you might want to rethink your suspension. Something firmer, that doesn't give as much or have as much rebound might be better.
How do you drive a car like you stole it with a ridiculous set-up? Your bound to cause damage, so why do it? I'm thristy, u?
Old Apr 5, 2013 | 12:27 AM
  #8872
Rjblayz's Avatar
Anybody know if I want to throw on the 03-04 rear OEM bumper with nismo rear lip on my 05, do I need the mudguards as well? Or can I just buy the bumper and lip and boom pair it together?
Old Apr 5, 2013 | 06:57 AM
  #8873
Blue Dream's Avatar
I drove ttrank's car solo
You need the mudguards.
Old Apr 7, 2013 | 05:42 PM
  #8874
JDMswagSerf's Avatar
what's up everyone I'm back.
I sold me sedan a week ago.
but before I sold it, my steering wheel was severely crookedn from a month ago where I drove fon dirt onto pavement and not realizing the pavement was hire and I hit it and my alignment went wack.
I adjusted the tie rods so the wheel could be center lol.
but as I did this, sometimes I I aligned it wrong, the trac and ses light would come on.
then u adjusted it so the wheel was straight and no lights.
but why would those lights come one. is the ecu tht smart to know that the alignment is that messed up?
ISO a g coupe or a Z now!
Old Apr 7, 2013 | 05:49 PM
  #8875
TORETTO's Avatar
Old Apr 7, 2013 | 10:33 PM
  #8876
DVG's Avatar
DVG
From all the problems you've been reporting with that car, it should have been scrapped for parts. I feel bad for whoever bought it
Old Apr 7, 2013 | 10:35 PM
  #8877
Airic214's Avatar
Old Apr 8, 2013 | 08:59 PM
  #8878
dominate's Avatar
Inven bumper for sedans 0.o http://www.ebay.com/itm/03-04-G35-SE...857c3e&vxp=mtr
Old Apr 9, 2013 | 12:20 AM
  #8879
bigjee's Avatar
Hey guys wanted someone info to make sure ive pin pointed the issue so I can order the right parts.
1) When making U turns if I step on the gas more or am carrying a lot of speed; the car makes a metal clanking sound (its pretty loud and is very annoying). When I straighten my steering wheel the sound disappears. Are my wheel bearing shot?
2) Brake rotor on the front left side has a crack in it. Im considering Stop tech slotted and OEM rotors. Which is better? Price difference between the two is about $40 in total for 4 rotors.
3) Looking to get rotors, pads and bearing hub assemblies changed (if the problem in 1. is the wheel bearing) so how long should it take the shop to work on all 4 wheels.
Thanks in advance.
Old Apr 9, 2013 | 12:36 PM
  #8880
thegreatkwijibo's Avatar
Originally Posted by dominate
Is that for real? I would kill for one of those...
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
