Random Little Question Thread
Old Apr 9, 2013 | 11:24 PM
  #8881
goodkuush's Avatar
Cat delete
i just wanna know if anyone has taken out their cats and just put a regular pipe there. i wanna know how it wuld sound before i do it becasue one of my cats is going bad but i dont have emmisions for another 2 years and hopefully by then ill have money for a n exhaut but for now im having someone take them out in a way so that it would be possible to put them right back on. so again just wanna know how it would sound ?
Old Apr 10, 2013 | 12:49 AM
  #8882
6mtg's Avatar
It doesn't sound bad it is a little louder than stock..just don't take the resonator out of the mid pipe and it will sound good
Old Apr 10, 2013 | 01:15 AM
  #8883
gary c's Avatar
Is this what G35 owners have stooped to? =0(
If your OE cats are going bad the "Right Way" to replace them is with high flow cats. Just adding a pipe in place of the cats won't work because you have sensors and your G won't run without them in place.
Gary
Old Apr 10, 2013 | 01:22 AM
  #8884
6mtg's Avatar
You don't need the rear o2 sensors to run. But I do agree ^ high flo cats or test pipes is the way to go (essentially a test pipe is just a pipe with a flange and a o2 bung)
Old Apr 10, 2013 | 12:50 PM
  #8885
goodkuush's Avatar
Radio
can i swap my stock radio for the bose one and just simply plug it in and it will work or is there more to it
Old Apr 10, 2013 | 12:52 PM
  #8886
goodkuush's Avatar
yeah hes gonna put pipes with flange but idk about the o2 thing and i mean they passed emission this time so well see what happens in 2 years cuz i dont have money for high flows right now :/
  #8887
goodkuush's Avatar
can u put up a video
Old Apr 10, 2013 | 07:02 PM
  #8888
Peoria35sedan's Avatar
You need the O2 sensors to keep the ecu from richen up the mixtures, the secondary ones need to be installed with spark plug extensions, that way the readings are different making the ecu believe the cats are functioning properly.
Old Apr 10, 2013 | 07:03 PM
  #8889
TunerMax's Avatar
G35
What you are asking about is called a test pipe. They are very common. They will throw a code if you don't have anti foulers or o2 Sims. It will also smell really bad and is illegal.
If you decide to do it be aware of those above things.
Also they don't sound good they rasp.
Old Apr 10, 2013 | 07:49 PM
  #8890
Beef's Avatar
Halpp
My front passenger side wheel starts shaking when I drive above 90km roughly. I just spent money on a new upper control arm and it still shakes. Any ideas??
Old Apr 10, 2013 | 08:03 PM
  #8891
Corpse11's Avatar
The wheel is isn't balanced, shock is shot, wheel bearing is shot, internals of the tire can be busted...it could be a lot of things...
Old Apr 12, 2013 | 06:13 PM
  #8892
goodkuush's Avatar
can someone please answer my radio question ^
Old Apr 12, 2013 | 07:08 PM
  #8893
DVG's Avatar
DVG
Its been 2 days and 5 posts since you asked. If somebody knows, they will tell you. No need to remind us that you asked
Old Apr 12, 2013 | 11:01 PM
  #8894
TunerMax's Avatar
G35
Try audio forum and do some more digging.
I don't know for sure but I can tell you that almost all the other nissans you can not do this simple swap. Pretty much everything is different. I have no clue about the G but I'd bet it is the same deal
Old Apr 13, 2013 | 03:52 AM
  #8895
dofu's Avatar
20 Year Member
You might need a new harness, but beyond that, both systems are 2 ohm so it should be somewhat plug and play. But it will still sound like crap unless you have the Bose speakers, amp, and sub to go with it. IMHO, you really want to ask a stereo shop for a definitive answer.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
