Random Little Question Thread
Rating: Thread Rating: 7 votes, 5.00 average.
Old Apr 26, 2013 | 12:13 PM
  #8986
Ednica87's Avatar
Are the side markers on the 03-04 bumpers the same as the 05-06. Sedan? Replacing bumper to a 06 one.
Old Apr 26, 2013 | 01:52 PM
  #8987
TORETTO's Avatar
This thread should be moved out of the sedan section, and into a general subforum.
Anyway, don't know if it's the same for coupes and sedans. But anyone know what size (diameter) of the bolt/nut that attaches the bottom of the coilovers to the spindle/arms/thingy.
May need to swap mine out since the head is stripped (going to be removing it with a stripped bolt remover) and would likely need a replacement for it.
Old Apr 26, 2013 | 01:57 PM
  #8988
TORETTO's Avatar
Originally Posted by Kyle Barbaro
when can I find parts PRE-painted ? just the market place or are there vendors?
Some vendors are willing to accept extra payment to have your body kit pieces pre-painted for you. Maybe you'd have a hard time finding it for G35's but it's a choice some vendors have. Other than that, used pieces in private classifieds is your only choice.
You're GOING to pay for paint no matter what, so there's really no difference in getting it pre-painted, or painting it after you receive it. Personally, I would not buy brand new body kit pieces painted, since fitment might be poor (unlike preowned, where fitment is known), you'd likely need to cut it/modify it so much that it will need repainting all over again, making you spend double.
Old Apr 26, 2013 | 02:01 PM
  #8989
TORETTO's Avatar
Yes, i believe they are the same.
Read:
https://g35driver.com/forums/g35-sed...edan-faqs.html
or more specifically:
https://g35driver.com/forums/2585132-post10.html
Old Apr 26, 2013 | 02:16 PM
  #8990
dofu's Avatar
20 Year Member
You should not have any problems with pre-painted parts, but like what has already been said, fitment might be an issue.
Since these cars are getting older, I'd also worry about color matching. You shouldn't have to worry about it, but it is still another thing that can go wrong.
Like mentioned before, you're going to pay about the same for the part to be painted whether the vendor sends it to you painted or if you find your own shop to paint it for you, so you might as well do the little bit of work and be sure you got it done right.
Old Apr 26, 2013 | 04:27 PM
  #8991
dominate's Avatar
So I'm currently running revised 350z springs on new KYB GR-2's meant for the revised Z suspension.
Current spring rate
Front:314 Rear:427
I'm considering dropping another .5" on Eibach coupe pro-kits with the spring rate of
Spring rates in LBS initial/final front 229/337 initial/final rear 274/463
How much faster (I know it's only an estimate) would my shocks wear out due to the higher spring rate? Would this not be a good idea at all?
Thanks
Old Apr 26, 2013 | 06:33 PM
  #8992
TunerMax's Avatar
G35
Originally Posted by dofu
05+ have a different style gauge cluster as the earlier models as well.
yup sorry the 05/06 is black with orange shenanigans
Old Apr 28, 2013 | 11:56 AM
  #8993
Rob902's Avatar
04 g35x sedan
Wondering if my buddies 2003 350z exhaust manifold will fit my awd 04 g35 sedan?
Old Apr 28, 2013 | 10:27 PM
  #8994
thescreensavers's Avatar
Mr.202?
Current spring rate
Front:314 Rear:427
Thanks
No one really knows there isnt a formula, just run them. When they wear out they wear out.
Old Apr 29, 2013 | 05:02 AM
  #8995
Flipperbat's Avatar
2005 Bumper question
Can anyone tell me what this bumper is off of or if its aftermarket?
Old Apr 29, 2013 | 05:12 AM
  #8996
dominate's Avatar
It's a G35X bumper. X models have that vent in the middle.
Old Apr 29, 2013 | 09:17 AM
  #8997
Mustang5L5's Avatar
Factory OEM 2005-2006 G35x AWD model bumper.
The RWD model bumper won't have the center vent
Old Apr 29, 2013 | 12:36 PM
  #8998
Flipperbat's Avatar
Thanks for the replays.
Old Apr 29, 2013 | 05:35 PM
  #8999
G35xSam's Avatar
Gear select windows next to AT shifter, supposed to be lit up?
Quick question that the search didn't really help me with:
In my new (to me) G35x the P, R, N, & D, don't light up when I move the shift select into each one. There looks like there's a little red piece that moves from one to the next, but at night it's not illuminated. Should it be? If so, can I just pull up on the plastic plate that surrounds the shift **** to expose the bulb? I don't want to break any trim pieces and it seems to me like these should be lit at night.
Thanks!
Old Apr 29, 2013 | 08:41 PM
  #9000
jayflyxx's Avatar
yes, they are.. call you dealer's part dept and ask them the size, I paid like $1.25 for it from the dealer and it was easy to replace!
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
