Random Little Question Thread
Old Jul 6, 2013 | 01:29 PM
  #9346
Drewtastic's Avatar
Originally Posted by TORETTO
I don't see how it failed visual with the carb sticker, unless it's missing. Also, I don't know about your smog tech, but when I take my car to the smog station, I pop my hood beforehand and ask them if they can see anything that they might fail visually prior to actually starting the smog test. They're usually nice enough to point stuff out that they're unsure of so you can take care of it before wasting money on a failed visual test.
It has the carb sticker on there. But theyre saying that the part is only legal for 03-04 G35s and not an 07 lol.
Old Jul 6, 2013 | 10:20 PM
  #9347
VINCE17's Avatar
What is he using in this video to monitor his engine???
Old Jul 6, 2013 | 10:55 PM
  #9348
OBsessed's Avatar
Why not shoot him a message? I'm guessing that's forum member RCDash
Old Jul 6, 2013 | 11:05 PM
  #9349
VINCE17's Avatar
Good idea, i didn't know that he was a member!..I'll do that.
Old Jul 7, 2013 | 08:23 PM
  #9350
Airic214's Avatar
is the 03-04 paint different from the 05-06 ? 05-06 looks shinier
Old Jul 7, 2013 | 08:30 PM
  #9351
g35loving's Avatar
It's going to be hard to say. Every plant Infiniti has uses a different paint as every car manufacturer is like that. And it changes every so many years. Now how it looks shinier could be it is taken care of better. I have seen 03 infinitis look better then the new ones. It all depends how well it is maintained
  #9352
TORETTO's Avatar
No it's just newer
Old Jul 7, 2013 | 08:32 PM
  #9353
Airic214's Avatar
yea i was comparing and the paint on the 05-06 looks newer
Old Jul 7, 2013 | 08:38 PM
  #9354
TORETTO's Avatar
Maybe because it is?
Old Jul 7, 2013 | 09:04 PM
  #9355
Airic214's Avatar
Old Jul 7, 2013 | 09:42 PM
  #9356
herrschaft's Avatar
Think about that for a second
Old Jul 9, 2013 | 05:24 PM
  #9357
The Stimulation's Avatar
Who knows if I'm doing this right or if it is even possible? I have an '06 sedan with the intellikey fob key, whatever. Keyless start so I don't need the key in the ignition. A while back I had a new ECU put in and the fob key no longer is making communications with the ecu so it acts as if it's the incorrect key.
Now I've done that reprogramming where you stick the key in 6 times and it flashes, etc, but it doesn't work for me. I thought that was for non-intellikey vehicles, but I tried anyway. Mind you, it's pretty difficult to flawlessly stick the key in all the way in and out every second. I don't think anyone could do that unless the ignition was made like it was for the 03-04.
I've also heard that these need to be programmed by the dealer using Consult II. Can anyone chime and specify what will actually work and what needs to be done to program this key?
Old Jul 10, 2013 | 05:23 PM
  #9358
pjgangsta's Avatar
G35X Revup
Can anyone Identify this Part so I can Order it?
The front bottom bumper on my passenger side is sticking out, because some clip or top part of this piece broke off somehow.
I can push the bottom bumper in to it's original position beneath the side marker lens, but without this piece part, it's useless.
It pops right out everytime..
There is a hole on the very edge of the bottom bumper...
There's a piece that goes in the hole and connects to a bracket
that is located beneath the side marker lens.
Anyone know what this piece is called or even better know the part # ? A clip maybe?
Tks
Attached Thumbnails Random Little Question Thread-20130710_155748_resized_1.jpg   Random Little Question Thread-b.jpg   Random Little Question Thread-c.jpg
Old Jul 10, 2013 | 06:28 PM
  #9359
Footballmania32's Avatar
It's a 10mm screw. Remove/examine the one on the driver side of the bumper to see what it looks like.
Old Jul 10, 2013 | 08:54 PM
  #9360
saywat?'s Avatar
so ur missing the screw or the plastic piece the screw screws in to?
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
