Random Little Question Thread
Old Dec 31, 2013 | 02:02 AM
  #9856
deejayy88's Avatar
So my buddy is selling his eibach spring lowering kit for 150$. Only thing is he has a g37 coupe. Will it fit my 04 g35 sedan?
Old Dec 31, 2013 | 09:28 AM
  #9857
NFSP G35's Avatar
? = 2B || !2B
Nope
Old Dec 31, 2013 | 05:50 PM
  #9858
dominate's Avatar
If I never track my car, would it not make sense to get softer spring rates on stance coilover for comfort? I was thinking 9k front 6k rear on around a 2.5" drop on a sedan.
Old Jan 2, 2014 | 05:28 PM
  #9859
rnguyen's Avatar
Do you guys think the motordyne plenum spacer is worth it??
Old Jan 2, 2014 | 05:42 PM
  #9860
NFSP G35's Avatar
? = 2B || !2B
^ Depends on how you classify "worth"
Old Jan 2, 2014 | 06:34 PM
  #9861
rnguyen's Avatar
Like can you feel the improvement in the car?
Old Jan 2, 2014 | 09:12 PM
  #9862
herrschaft's Avatar
Depends on how sensitive your butt dyno is. The plenum spacer is a good mod for the money.
Old Jan 2, 2014 | 10:43 PM
  #9863
rnguyen's Avatar
Sounds good. Easy to install??
Old Jan 2, 2014 | 11:08 PM
  #9864
Urbanengineer's Avatar
4/10 on ease of install with 1 being easiest. Reason being? You need access to an inch pound torque wrench. So many people break plenum using ft lbs :facepalm:
Old Jan 2, 2014 | 11:40 PM
  #9865
NFSP G35's Avatar
? = 2B || !2B
you don't reeeeaaally need an in-lb torque wrench... just need to not be an idiot.
Old Jan 2, 2014 | 11:55 PM
  #9866
You can rent one from autozone for free. They even give you the tax back and you can take the tool home.
Old Jan 3, 2014 | 01:00 AM
  #9867
rnguyen's Avatar
Okay cool thanks
Old Jan 3, 2014 | 11:22 PM
  #9868
dofu's Avatar
20 Year Member
Yea, that ^. You just need a bit of German torque, but not too much. Hand torque to just where it starts to tighten enough to where you need to start applying any real amount of muscle to turn it, then give it a quarter turn and you are done.
Old Jan 4, 2014 | 12:15 AM
  #9869
thegreatkwijibo's Avatar
MD even says that in their instructions that if you don't have an in-lb torque wrench then you just tighten it by hand. smh at anyone who actually fvcked up their car using a ft-lb wrench.
Old Jan 4, 2014 | 12:25 AM
  #9870
It's not so much about breaking the plenum with a hand wrench, it's more along the lines that you need to tighten your plenum correctly to prevent air leaks or warping over the years.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
