Burned 2 quarts after 5000 miles, oil consumption issue?
Old Dec 30, 2010 | 02:51 PM
  #31
Mustang5L5's Avatar
I run castrol gtx....it burns too
Old Dec 30, 2010 | 05:49 PM
  #32
thescreensavers's Avatar
Mr.202?
^ Have you tried 10-40?
Old Dec 31, 2010 | 12:08 AM
  #33
mikedamageinc's Avatar
If oil is disappearing try a PCV catch can. It wont stop it from going away but will keep it out of the combustion chamber and will run better. I couldnt believe how responsive mine was after installing one. (on other vehicles as well)
I dont understand how several people talk about getting less than 4 quarts drained from the engine. Thats means you've been driving around with low oil level, check it once a week and keep it full!
Old Dec 31, 2010 | 12:24 AM
  #34
Mustang5L5's Avatar
Not yet...doing some more reading on bitob before I give it a shot
Old Dec 31, 2010 | 01:28 PM
  #35
Bassman's Avatar
Is the engine actually burning the oil? Is it getting past valve seals, piston rings, ect.? Or is it evaporating and the vapors going out the pcv? When I first got my G I immediately put Amsoil 0W-30 in it. I was shocked when I was down a quart after 2000 miles. I now use Amsoil 5W-30 and add half as much as before. When I checked the specs on Amsoil's web site I found that the 5W-30 was less volitile. This makes me wonder it there is a hot spot aound cylinders 5&6. My wife's '05 Max has basicly the same engine turned sideways and uses 0 oil in 5000 miles.
So, does the oil flow to the back of the engine under excelleration? Only to be vaporized?
Old Jan 6, 2011 | 01:43 PM
  #36
jmueller's Avatar
Burning 2q every 5000 miles.. Never had the light come on though!
Old Jan 6, 2011 | 02:32 PM
  #37
Mr.202?
If the light comes on you SOL lol
Old Jan 6, 2011 | 09:52 PM
  #38
Mustang5L5's Avatar
Is the light a low oil pressure light? Or does it also record low oil level?
Some cars only do one, while some do both. What does the g35 monitor?
Old Jan 6, 2011 | 11:10 PM
  #39
Mr.202?
I think its a pressure light.
Old Jan 7, 2011 | 08:04 PM
  #40
RADIOGUY21's Avatar
its a low pressure light, and for it to illuminate due to lack of oil, it means you are VERY low on oil.
Ken167
Aug 7, 2015 11:12 AM
ghost_g35
Aug 7, 2015 10:31 AM
lemmy999
Jul 25, 2015 12:13 PM
ClwMike
Jul 23, 2015 12:55 PM
mjfenix
Jul 17, 2015 02:07 PM
