ok ive searched and searched...
Old Aug 6, 2011 | 03:33 PM
turk in gm's Avatar
and i havn't found a thread that answers my question.
I've been reading about the coupe mid pipe swap and have seen pictures of this.
My question is though, would it be possible to just weld flanges onto a straight pipe (no bends) and have it run from the y-pipe flange directly to the OEM axle back flange? It seems pretty straight to me from only looking at it underneath the car. I plan on pulling that section out to tomorrow anyways but knowing what im in for would be better.
Also this is my first post so ill post my car.
2004 6mt just broke 100k.
Thanks for the advice.
Old Aug 6, 2011 | 03:37 PM
turk in gm's Avatar
Im sorry this is in the wrong section. could a mod move this to the sedan section. Thank You
Old Aug 6, 2011 | 03:51 PM
faiz23's Avatar
You can do anything that floats your boat as long as you have $$$$$. Keep in mind you might get a ton of rasp or drone since you do not have a resonator what so ever except the rear can. If I am not mistaken the 2003-2004 have a smaller muffler so it tends to be louder now imagine how loud it would be with a straight pipe to the muffler. Have you seen what a 2003 midpipe looks in comparison to a 2005 midpipe and what a coupe midpipe looks like. If you remove the resonator completely please carry some earbuds for your passengers.
Old Aug 6, 2011 | 04:03 PM
TIAN's Avatar
Hold The Line
+1. It's most likely going to be loud and raspy.
Thread moved
Old Aug 6, 2011 | 04:07 PM
turk in gm's Avatar
im completely ok with the "drone."
Im not looking for the cheapest way out, just looking for a way to remove the midpipe with a straight(ish) pipe. I printed out some diagrams of the exhaust system for the sedan and heres what i was basically looking for.
edit. thank you for the move
Old Aug 6, 2011 | 04:12 PM
SDGenius's Avatar
do NOT run a straight middy, it WILL drone badly. i don't even recommend the coupe mid-pipe, just do the 05-06 sedan middy if you wanna do a cheap upgrade.
Old Aug 6, 2011 | 04:15 PM
turk in gm's Avatar
ok ok. so the straight pipe idea apparently is the worst idea ever haha.
Old Aug 6, 2011 | 04:17 PM
SDGenius's Avatar
it's a horrible idea w/the stock setup
Old Aug 6, 2011 | 04:20 PM
turk in gm's Avatar
guess its back to searching for a coupe midpipe.
Old Aug 6, 2011 | 05:56 PM
IPGdriver's Avatar
G35 Sedan
What you're talking about is a resonator delete. imo its too raspy. You should try taking the muffler off and see how you like it..its a good, easy DIY. That's what i did and actually love it. It just deepens the tone of the exhaust, doesn't make it raspy. And with the stock 04/03 mid pipe (which is HUGE) it won't be too drone-y!
Old Aug 6, 2011 | 07:53 PM
007JD's Avatar
y not coupe mid ??
i would have told him
hr y pipe .. wit coupe mid and stock 04 muffler
Old Aug 6, 2011 | 07:59 PM
JaE35's Avatar
Moderator
G35 Sedan
the coupe or z mid-pipe is fantastic...sounds a lot better than the 05/06 sedan middy as well...do not do a straight pipe lol
Old Aug 6, 2011 | 09:38 PM
turk in gm's Avatar
Originally Posted by 007JD
y not coupe mid ??
im looking, but man are they hard to find used...but this seems like my next option.
Old Aug 6, 2011 | 10:01 PM
SDGenius's Avatar
y not coupe mid ??
coupe/z middy's aren't worth the drone, if ur exhaust is gonna be loud it better be powerful.
AL8782
Oct 3, 2015 10:26 AM
Visionnn
Oct 3, 2015 05:16 AM
Learned Hand
Oct 1, 2015 09:02 AM
Jcruzg35
Sep 26, 2015 04:47 PM
