No start no power to ecu
Old Jul 26, 2019 | 12:50 AM
Thatbroke_G35's Avatar
So i have an early 03 sedan I purchased pretty cheap ($700) cause it had a bad transmission leak I swapped the transmission and replaced the dead battery and while i was replacing the battery i ripped out a kill switch that was in it not really knowing why it was on there but apparently it was jumping the ecu relay and without it the ecu has no power im not sure if that can be the ipdm being bad or there could be something else causing it i already swapped the ecu relay thinking it was bad but it didnt change anything
Old Jul 26, 2019 | 04:53 AM
05_SkylineSedan's Avatar
20 Year Member
https://nicoclub.com/FSM/G35/Sedan/2003/
or more specifically:
https://nicoclub.com/FSM/G35/Sedan/2003/pg.pdf
Old Jul 26, 2019 | 11:11 AM
Originally Posted by 05_SkylineSedan
I have been using alldata to trace wiring on it back to the ipdm and everything seems to be working but no power to the ecu and also i just remembered the radiator fan stays running with the key in the ignition i couldnt find any info on the plugs going into the ipdm on alldata so i wasnt able to trace those thats why im not sure if it is the ipdm or not but i have to run to the junkyard today i might try to pull the ipdm out of a wrecked G sedan there i think theres 4 of them but only 1 is an 03
Old Jul 27, 2019 | 12:03 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
It has to be the EXACT same IPDM, same with the ECM. I wouldn't use the alldata infor for stuff like that, the FSM on NICOCLUB has all the correct data.
What pin at the ECM are you checking for power?
Old Jul 27, 2019 | 12:04 PM
cleric670's Avatar
BANNED!!!
Also if you replace the ECM it has to be programmed by the dealership. They are NOT plug-n-play.
Old Jul 27, 2019 | 12:10 PM
I dont remember the exact pins i had it saved on my phone but i cant find it but there is a pink wire that gets 12v with the key on which is from the ecu relay and it doesnt get power at the plug for the ecu i doubt my ecu is bad if the loss of 12v is at the plug not the ecu and if i did have to replace the ecu im a mechanic and can program my key to the new ecu myself at work
Old Jul 29, 2019 | 01:04 PM
Well nvm the ipdm was definitely dead im surprised everything else worked with it the only thing that didnt work was the ecu relay but it ran and drove fine with the kill switch that jumped relay i got the ipdm swapped with one out of another 03 sedan same numbers on the ipdm but i have to wait until monday to try to start it the car is parked at the shop i used to work at cause i used the lift there to swap my transmission and they are on vacation until monday but heres a few pics of the old ipdm
Old Jul 29, 2019 | 03:59 PM
cleric670's Avatar
BANNED!!!
Ahh yeah that's definitely water damage, clean and enlarge the cowl drains, they're probably clogged. Common problem and when the cowl fills with water it drains off onto the IPDM.
Old Jul 29, 2019 | 04:01 PM
Previous owner had the cowl off at some point and it wasnt installed correctly im getting new clips for it tomorrow since all of them were missing
Old Jul 29, 2019 | 04:11 PM
cleric670's Avatar
BANNED!!!
Yep that will do it too, glad you found something obviously wrong. Mystery broken parts are such a pain in the ***.
Old Jul 29, 2019 | 04:14 PM
Yea they really are honestly i wish i had more money to spend though they have a full 6spd swap perfect black interior minus a missing door panel and the door that covers the dvd player for navigation is falling apart and i need a rear bumper and i want to do away with the doggy door trunk lid
Old Aug 5, 2019 | 02:16 PM
Well i got the key and tried to start it same thing so i can rule out the ipdm since i replaced it with a good one this is weird i thought for sure it would be the ipdm since the old one had water damage
Old Aug 5, 2019 | 07:45 PM
Never mind i fixed it pin 33 on the ipdm wasnt getting power so its jumped right now until i get it home but bank 2 cam sensor died while it was sitting so its going to sit a few more days until i get a new one
Old Aug 5, 2019 | 08:51 PM
Masyi Mims's Avatar
New to the Game and trying to get her right
Can it be my ecu or something else
Ive recently bought a 06 sedan automatic and my main problem is it hardstarts! it tends to turn on the first crank but it doesnt even sound like a healthy turnover but when i drive it, its smooth (except for the sputtering and stalling that would happen before all the work) so far ive replaced the fuel pump, cams and crank and had the ecu programmed along with getting a new remote for my key, i called an infinity specialist and told him the same thing and he believes i gotta replace the ecu so before i spend that type of money anyone else have any other suggestions
G Thunder
V36 General Tech Questions
Dec 11, 2013 09:45 AM
Xman
Tuner & Dyno
Dec 6, 2005 08:14 PM
chuckd05
Sep 13, 2004 02:42 PM
ramo
11
Jun 25, 2004 05:59 PM
cato
Jul 26, 2003 09:21 PM
