will the m45s shift knob fit on the 07 g35s
Old Dec 10, 2007 | 04:12 PM
  #46
Jason@Riverside's Avatar
I just looked at an M and G side by side...
Looks like the trim piece that snaps into the bottom of the G shift **** is a different shape than the M piece...
So, in order for it to work, a new boot w/ trim piece is going to be needed...
The only way to get the boot / trim piece is with the complete indicator assembly...
the indicator assembly is not going to fit into the new G...
Sorry it does not look like it is going to work...
Old Dec 10, 2007 | 04:25 PM
  #47
kre62's Avatar
I guess Im not well versed in ****-ology but isnt there some way to just attach the **** part? THeres got to be some way to do this.
Old Dec 10, 2007 | 04:31 PM
  #48
It looks like the **** its self will go onto the shaft, but the boot will not attach...
If you look at your stock ****, the shift boot is attached to the bottom of the shift ****...
If you pull down on the ****, you will see how the boot / **** is seperate and you gain access to the pin to pull off the ****...
Old Dec 10, 2007 | 04:48 PM
  #49
kre62's Avatar
Well is it possible to get the little trim piece for the M **** and attach that to the G35 boot leather? Then itll snap right on. We need to think outside the box here now whenever I look at my **** it looks ugly to me. I need me some M ****.
Old Dec 10, 2007 | 04:50 PM
  #50
fecurtis's Avatar
****-ology...thats a great new slang word for oral sex.
"Excuse me ma'am, you wouldn't happen to be an expert ****-ologist would you?"
Old Dec 10, 2007 | 04:54 PM
  #51
Old Dec 10, 2007 | 05:02 PM
  #52
kre62's Avatar
Aha but that DOSENT answer my question as well as you thinki t does Jason. Im not talking about replacing the indicator assembly. Im talking about removing the trim piece from the M boot and attaching it to the G boot. Probably would cost too much but could it be done is the question.
Old Dec 10, 2007 | 05:15 PM
  #53
The only way to get the TRIM PIECE is by getting the BOOT... The only way to get the BOOT is to get the complete ASSEMBLY.
The TRIM piece is not available on its own.
In order to get the TRIM Piece you would have to purchase the INDICATOR ASSEMBLY.
Then take the TRIM piece to an apholstry shop to get onto the leather boot of the G indicator (also only available with the indicator assembly).
Old Dec 10, 2007 | 05:39 PM
  #54
kre62's Avatar
So basically what you are saying can be summed up with this word "yes". As in yes the piece can be attached to the G boot, just takes a lot more work. How much is the assembly?
Old Dec 10, 2007 | 05:46 PM
  #55
The indicator assembly is $115 LIST I would beable to discount it... but parts alone, you will be looking at around $200 plus any work needing to be done...
Old Dec 10, 2007 | 06:26 PM
  #56
ABQ_G35's Avatar
Not quite worth the trouble it sounds like. Oh well, the G AT **** is just fine!
Old Dec 10, 2007 | 06:45 PM
  #57
viguera's Avatar
So the assembly comes with the indicator, which comes with the boot, which I can take off and put on the G.
Do you take paypal?
Old Dec 10, 2007 | 06:49 PM
  #58
Yes I do take paypal...
The best thing to do will be to remove the shifter boot and get it onto the G shift indicator... The M indicator is larger so the boot will have to be fitted to the G...
Viguera: If you want to be the first to try / modify the parts needed PM me and I will try to work something out for you...
Old Dec 10, 2007 | 07:06 PM
  #59
kre62's Avatar
Vig if you get the stuff and do a DIY on how to get it to work you will be a god among forums.
Old Dec 10, 2007 | 07:19 PM
  #60
viguera's Avatar
Damn, I wouldn't know about that...
But I'm sure it works like this: get stuff from M, put it on the G.
There's your write-up.
